Introduction: Opencv Python Hand Detection and Tracking
Aim of the project is to move a robotic hand, mimicking humand hand based on a camera feed.The project is divided into
- Software (i'm using opencv to detect human hand and find the distance between palm center and finger tips. Popular method of convex hull and convexity defect is used to detect the movement of hand.)
- Hardware (pc/raspberry pi)
Step 1: OpenCV HAND Tracking Code
python code you can get it from here
import cv2
import numpy as np
import copy
import math
import os</p><p>def calculateFingers(res, drawing):
# convexity defect
hull = cv2.convexHull(res, returnPoints=False)
if len(hull) > 3:
defects = cv2.convexityDefects(res, hull)
if defects is not None:
cnt = 0
for i in range(defects.shape[0]): # calculate the angle
s, e, f, d = defects[i][0]
start = tuple(res[s][0])
end = tuple(res[e][0])
far = tuple(res[f][0])
a = math.sqrt((end[0] - start[0]) ** 2 + (end[1] - start[1]) ** 2)
b = math.sqrt((far[0] - start[0]) ** 2 + (far[1] - start[1]) ** 2)
c = math.sqrt((end[0] - far[0]) ** 2 + (end[1] - far[1]) ** 2)
angle = math.acos((b ** 2 + c ** 2 - a ** 2) / (2 * b * c)) # cosine theorem
if angle <= math.pi / 2: # angle less than 90 degree, treat as fingers
cnt += 1
cv2.circle(drawing, far, 8, [211, 84, 0], -1)
if cnt > 0:
return True, cnt+1
else:
return True, 0
return False, 0
# Open Camera
camera = cv2.VideoCapture(0)
camera.set(10, 200)</p><p>#while True:
while camera.isOpened():
#Main Camera
ret, frame = camera.read()
frame = cv2.bilateralFilter(frame, 5, 50, 100) # Smoothing
frame = cv2.flip(frame, 1) #Horizontal Flip
cv2.imshow('original', frame)
#Background Removal
bgModel = cv2.createBackgroundSubtractorMOG2(0, 50)
fgmask = bgModel.apply(frame)</p><p> kernel = np.ones((3, 3), np.uint8)
fgmask = cv2.erode(fgmask, kernel, iterations=1)
img = cv2.bitwise_and(frame, frame, mask=fgmask)
# Skin detect and thresholding
hsv = cv2.cvtColor(img, cv2.COLOR_BGR2HSV)
lower = np.array([0, 48, 80], dtype="uint8")
upper = np.array([20, 255, 255], dtype="uint8")
skinMask = cv2.inRange(hsv, lower, upper)
cv2.imshow('Threshold Hands', skinMask)</p><p> # Getting the contours and convex hull
skinMask1 = copy.deepcopy(skinMask)
contours, hierarchy = cv2.findContours(skinMask1, cv2.RETR_TREE, cv2.CHAIN_APPROX_SIMPLE)
length = len(contours)
maxArea = -1
if length > 0:
for i in xrange(length):
temp = contours[i]
area = cv2.contourArea(temp)
if area > maxArea:
maxArea = area
ci = i</p><p> res = contours[ci]
hull = cv2.convexHull(res)
drawing = np.zeros(img.shape, np.uint8)
cv2.drawContours(drawing, [res], 0, (0, 255, 0), 2)
cv2.drawContours(drawing, [hull], 0, (0, 0, 255), 3)
isFinishCal, cnt = calculateFingers(res, drawing)
print "Fingers", cnt
cv2.imshow('output', drawing)
k = cv2.waitKey(10)
if k == 27: # press ESC to exit
breakoutput should be
Step 2: Python and OpenCV Installation
you can find the Opencv and Python Installation Instructions here
