Introduction: Oreo Cookie Brownies
These brownies are unlike any you have tasted! They use not only brownie batter, but cookie dough and Oreos as well. And best of all, they're incredibly easy to make! You'll only need about 45 minutes from start to consumption. Let's get started...
Step 1: Ingredients
You'll need:
- 1 3 dozen chocolate chip cookie mix
- 1 13x9 brownie mix
- 1 package of Double Stuf Oreos
- 1 tablespoon of olive oil
- 1/2 cup of water
- 1 stick of butter
- 2 eggs
Step 2: Preheat Oven
Preheat the oven to 350 degrees Fahrenheit.
Step 3: Wash Your Hands
Don't forget to wash your hands!
Step 4: Making the Cookie Dough
Follow the instructions on the back of your cookie mix. For this specific package, we started by pouring the mix into a large mixing bowl. Next, we added 1 stick of softened butter to the mix. Lastly, we added 1 egg. We then mixed the dough ingredients together until it was a soft, doughy consistency.
Step 5: Adding the Cookie Dough to the Pan
First, grease the pan with Pam or a similar oil spray to prevent the dessert from sticking. Then smush the cookie dough into the bottom of your 13x9 pan. Make sure the cookie dough covers the entire surface.
Step 6: Adding Oreos to the Pan
Now, add the Double Stuf Oreos to the pan. Simply lay down the Oreos to create a single layer on top of the cookie dough.
Step 7: Making the Brownie Mix
For our third component, follow the instructions on the back of your 13x9 brownie mix. For this specific mix, we first poured the dry brownie mix into a large mixing bowl. We then added the 1/2 cup of water, 1 tablespoon of olive oil, and 1 egg. Stir the mix until it is a creamy consistency.
Step 8: Adding the Brownie Mix to the Pan
Pour the brownie batter on top of the Oreo layer. Spread out the batter to cover all of the Oreos. Gently shake the pan from side to side on the counter to even out all of the mix.
Step 9: Putting the Oreo Cookie Brownies in the Oven
Put the Oreo Cookie Brownies into the oven, and set a timer for 30 minutes.
Step 10: Taking the Oreo Cookie Brownies Out of the Oven
Remove the dessert from the oven once the timer is up. Be sure to protect your hands from the heat!
Step 11: Cutting the Oreo Cookie Brownies
Cut the dessert into any shape you prefer. I usually cut them into 1-Oreo-sized portions.
Step 12: Consume!
Enjoy! Optional: ice cream on top!
