Introduction: Oreo Popcorn
Need a tasty treat for that next party or for your kids’ afternoon snack? We have a simple treat that takes less than 15 minutes to prepare. This is the perfect snack for you and is a crowd favorite. Oreo Popcorn will be your new “go-to” party treat!
Step 1: Materials
3 Bowls: (1 Microwavable, of the remaining two, one needs to be slightly bigger than the other)
Potato Smasher (the black item)
Stirring Spoon
Aluminum Foil/Wax Paper
Container/Ziploc Bags
15 Oreos
1 Bag of Popcorn
4 Bars of Almond Bark
Stirring Spoon
15 Oreos
1 Bag of Popcorn
Step 2: Sanitize Work Area
Sanitize your hands, work area, and put back your hair
Step 3: Lay Out Foil
Lay out 2 sheets of Foil/Wax Paper (each about 2 feet in length) on an open counter top
Step 4: Pop the Popcorn
Pop the popcorn - it can be buttered or kettle. Be sure to follow the popcorn’s instructions (lay flat, this side up)
Step 5: Crumble the Oreos
Crumble the Oreos - Place 15 Oreos in a bowl. Use the potato smasher to crumble the Oreos. They can be crumbled according to your liking
Step 6: Remove Unpopped Kernels
Separate the Kernels from the Popcorn-
remove the popcorn from the bowl and place into the bowl with the Oreos’ using your hands to remove the un-popped kernels.
Step 7: Combine Oreos and Popcorn
Mix the Popcorn and Oreos –
move the popcorn and Oreos from one bowl to the other, so that the mixture is evenly mixed
Step 8: Melt Almond Bark
Melt the Almond Bark –
Place 4 bars of almond bark in the microwavable bowl. Microwave it for 30 seconds and then continue to microwave it in 15 second intervals. Stir between intervals until it is completely melted.
Step 9: Mix Almond Bark and Popcorn Mixture
Add the melted Almond Bark to the Oreo and popcorn mixture
Step 10: Mix the Ingredients
Place one bowl on top of the other then carefully shake it until somewhat mixed. Be aware that it is easy for the popcorn to fall out of the bowls
Step 11: Stir Mixture
After shaking, stir the mixture until it is evenly coated with the Almond Bark
Step 12: Spread Mixture
Spread the Oreo/Popcorn/Almond Bark mixture onto the foil
Step 13: Let Mixture Sit
Let the Almond Bark harden for 5-10 minutes
Step 14: Store and Serve
Once hardened, break up the popcorn mixture. Place it in a container to store/serve
