Introduction: Oriental Inspired Box
Ive always loved Japanese / oriental projects and themes etc, i find them really relaxing.
So i came up with this idea for a box, made from scrap as always but with a oriental feel to it.
I hope you enjoy!
Please leave a like, share & comment. And subscribe for more like this!
Watch my builds - https://www.youtube.com/channel/UCRMjvilGRdZxHqr34QKzB_Q
Follow my work on instagram - https://www.instagram.com/ggwoodproje...
Help me make more projects- https://www.patreon.com/GGWoodwork
Thanks GG
Step 1: Cutting
As always 1st thing i do is to cut all my pieces down to size, i started with the lid and put a heavy bevel all around the edge, next i used a 2x4 and some other scrap to make up the box itself.
The overall size turned out at 83mm L x 54mm W x 57mm H
The lid turned out to be - 96mm L x 58mm W x 8mm thick
Step 2: Glue and Hollow
I glued up the box and used a spade bit to hollow out most of the box and cleaned it all up with a chisel
Step 3: Cork
I added a small strip of cork to the bottom , using titebond 2 works well to glue cork to wood, and i just used some stones to weight it down while it dried
Step 4: Handle
For the handle i used a thin scrap of wood, and cut a 45 on each side, and i used 2 6mm dowels to attach it to the lid
Step 5: Drill for Dowels
I wanted the handle to sit above the lid, so i drilled some holes for the dowels and only drilled a little way into the handle this gave it a nice height and look
Step 6: Sand and Glue
I sanded the lid and handle from 120 to 1,200 and glued it in place, once it was dry i trimmed the dowels flush and sanded them down again
Step 7: Sand and Drill
Next i sanded the outside of the box to 1,200 , next i drilled out some holes for 4mm x 1mm magnets , i just used super glue to keep the magnets in place
Step 8: Final Sand and Finish
i sanded all the glues parts and magnets to 1,200 and it was on to finishing, to finish i used 4 coats of spray lacquer sanding at 1,200 in between coats
Step 9: Job Done
Thats it , job done, a great Japanese / oriental inspired box.
The finish is glass like and i love how it turned out.
I hope you do to.
I hope you enjoy!
Watch my builds - https://www.youtube.com/channel/UCRMjvilGRdZxHqr3...
Follow my work on instagram - https://www.youtube.com/channel/UCRMjvilGRdZxHqr3...
Help me make more projects- https://www.youtube.com/channel/UCRMjvilGRdZxHqr3...
Thanks
GG
