Introduction: Origami Bamboo Sleeve and Yoke Dress
Hello everyone..... although i have been subscribing to instructables, I have never made one myself. When I saw this contest, I thought this is a good opportunity to start with.
I have tried to explain the best I could but this is a very confusing pattern and this instructable is preferable for those who have prior pattern drafting and sewing knowledge.
Step 1: Things You Will Need
- Paper for drafting (any paper will do including newspaper)
- Pencil
- Ruler
- masking tape
- pins
- scissors
- fabrics - I have used 2 different fabrics which I had at hand. However, it is preferable to use a solid colored fabric to enhance the bamboo effect
- basic extended bodice and sleeve pattern
Step 2: The Sleeve (pattern)
- Take your basic sleeve pattern..... for this style to be enhanced , you need to have long sleeve (which I hate so I went with the shortest possible length with 6 bamboo slants)
- Decide on the number of bamboo slants you need and number them from the hem line
Step 3:
- Cut line 1 till the edge but not completely
- Insert a triangular piece of paper +- 12 cm at the base
- Stick with masking tape
- Draw over the lines
- Pin the triangle at the line and fold the pleat
- Cut the excess at the hem and side seams
Step 4:
- For bamboo slant no.2....... cut along the top edge of the first pleat until the line 2 intersection
- Cut along line 2 till the edge
- Follow same instructions as you did for line 1
Step 5:
- Go along line by line working your way up towards center of sleeve
Step 6:
- Finish all 6 lines .... at this point... I found that the pattern overlapped and I couldnt place it flat on the fabric so i added one more slit at the center and made another small pleat so that I could lay the pattern flat without overlap
Step 7: Sleeve (Cutting on Fabric)
- Pin on fabric (you will need lots of pins)
- Cut the pattern out on fabric
- DO NOT stretch the fabric while moving it to the ironing board
- Iron the pleats (you can do without ironing also)
Step 8: Sewing of the Sleeve
- Sewing of the sleeve is done in the reverse order of drafting..... that is .... you start sewing from the top (the last pleat) and move downwards towards the hem
- Details of sewing the individual pleat given with the yoke
Step 9: Yoke
- I made 5 bamboo pleats for the yoke
- The method is same as the sleeve
- Cut each line, add triangular piece, fold and cut excess
Step 10: Yoke on Fabric
- Pin the yoke pattern on fabric and cut
Step 11: Sewing of Yoke
- Like the sleeve, we start sewing from the last line (the 5th one)
- The first pleat (the fifth line) is not done like the bamboo pleat because it is too close to the neckline
- Therefore I made it like a dart with the excess on the right side of fabric
- Fold the 4th line,pin it (see the pic above)
- Fold the fabric upwards and sew a thin seam to secure the pleat
Step 12:
- Follow the same step for the next pleats until you finish all 5
- Sew the right lower corner to secure the last pleat (the last pic)
Step 13: Bias Band
- Take thin piece of fabric on the bias
- Place a thick thread and sew the bias band
Step 14: Attach the Bias Band
- Line the bias band on the edge of the yoke
- Iron the yoke with bias band
Step 15: Bodice
- Take extended bodice pattern
- I have made zig zag hem
- Cut on fabric
Step 16: Attach Yoke to Bodice
- Pin the yoke on the bodice pattern
- Sew top stitch on the sides
Step 17: Attach the Shoulders
- Pin the shoulders
- Sew the shoulders
- Overlock the seams to give a neat finishing
Step 18: Neck Facing
- Neck facing is cut for the front and back neck for the bodice
- The shoulder part of the neck facing are joined together and the edges overlocked
- Pin the neck facing to the main bodice right side to right side, pin the pieces
- Sew around the neckline
- Snip the seams so it is neater when you reverse it
- Understitch the neckline, iron it
- Hem the neckline
Step 19: Hem
- I used the yoke fabric for the bottom part of bodice
- Pin the zig zag and top stitch
- I used the border pattern on the fabric at the hemline
- Sew the side seams upto the zig zag only (as I wanted to make a side slit)
- Fold and finish the side slits
Step 20: Final Piece
I thoroughly enjoyed making this project and hopefully you will too when you replicate this origami bamboo pattern.
Thank you for your patience :)
