Introduction: Origami Cranes
In this instructable, I am going to show how to make cranes in origami. It could seem difficult at first, but the more you try, it is going to be very easy. This instructable will increase your creativity and give fun.
Follow the easy steps below and watch the video tutorial!
The only material needed for this is square paper. It can be any paper, including the origami paper I used for this instructable.
Step 1: Folding the Paper Into Squares and Triangles
Before you start to fold your crane, make sure that you have the side of the color you want your's to be facing down on the surface.
For the first step, you have to fold the paper into rectangles and triangles. You have to fold one rectangle, unfold, fold the other rectangle, unfold, and continue the same thing over for the triangles. The order of folding doesn't matter.
Step 2: Creating a New Square
Second, you have to unfold the rectangles and the triangles you folded, and use the lines you created to make one new small square.
Step 3: Going One More Step Further
For this step, with your new small square done, you should fold both sides of the square to the line in the middle, as shown in the picture. Then, you fold the top of the square as much as you can to the bottom.
You should do the same thing again turning the paper to the opposite side but leaving the top part.
Step 4: Folding More
https://drive.google.com/file/d/17Bch8Y7JPIsf2c9l3y6SmF9qunJw-Gjc/view?usp=sharing https://drive.google.com/file/d/1g3y5OKY3bVQYuqpRtD28-BL-rkxBkwbE/view?usp=sharing
These two links are the videos for this step orderly. You need to fold both the front and the back.
Step 5: Going Towards the End
After doing the previous step, you need to make the part where the paper splits go down. Then, you will fold the side of the papers to the middle. You'll see the line made on the paper which makes it easier for you to fold it.
Step 6: Almost the End
It is almost finished. You can watch these videos to step forward. https://drive.google.com/file/d/1nupLUN5fZ3lmjneBY3poIG_dXqTJV2fL/view?usp=sharing https://drive.google.com/file/d/1f0vbJcd9F8CFVsGnKcdgrtDJcjmapv0O/view?usp=sharing
The paper will now look a little bit like a crane.
Step 7: Finishing Up
Finally, you have to open the wings in the side by pulling them apart. Watching this video will help you do this. https://drive.google.com/file/d/1b_97vM4IQU6ZaUtLSuPS772Yrbx-Denz/view?usp=sharing
I hope you enjoyed folding origami craned looking at this instructable, thank you!
