Introduction: Origami Flower Blossom
Once upon a time in the 8th grade I was extremely bored in math class when I took a small piece of paper and began trying to make my own origami design from scratch. I knew enough about origami to know the basics, and after a while, ended up with this cute flower blossom. I retraced my steps to make sure I could remember how to make them, and ever since then I love this design and can proudly claim it as my own. These are perfect for paper bouquets, decorations, gift box toppers, and more. I hope you enjoy making this pretty little blossom!
Terminology:
  • Valley fold - Fold the paper to where the crease faces down
  • Mountain fold - Fold the paper to where the crease faces up
  • Preliminary base - The base that serves as a starting point for many traditional origami models
  • Bird base - The base that serves as a starting point for many traditional "bird" origami models
  • Squash fold - Push the paper down onto itself flat
1 piece of 15x15 cm square paper, any color
Note: Any size square works, but smaller than 15x15 can be difficult to work with. Use larger dimensions if you like to have more material to work with!
Step 1:
  • Make sure your paper is color-side down and fold two diagonal valley folds
Step 2:
  • Fold two horizonal valley folds across both sides of the paper
Step 3:
  • Fold the paper back into a triangle using one of the existing diagonal creases
Step 4:
  • Squash fold the right and left points. Fold the flaps over to their designated sides
  • You now have the Preliminary Base
Step 5:
  • Fold both sides of the tabs to meet the center. Repeat on the back
!!! Make sure the open part of the model is facing downwards !!!
Step 6:
  • Fold the triangle at the top down along the line at the top of the tabs
Step 7:
  • Unfold both tabs on one side. Open the model from the bottom.
Step 8:
  • Collapse upwards along the crease you just made
Step 9:
  • Repeat Steps 6-8 on the back
  • You now have the Bird Base
Step 10:
  • Fold the top edges of the model down to align with the bottom of the triangle crease. Squash fold the top half to make a "diamond" shape
Step 11:
  • Repeat on the back
Step 12:
  • Fold the entire right-side flap of the model to the left. Flip the model over and repeat
Step 13:
  • Fold the bottom triangle up along the existing crease. Repeat on the back
Step 14:
  • Repeat Steps 9-10
Step 15:
You should now have a "diamond" shape with a small triangle at the top
  • Fold the right side of the model flap over to the left and squash flat. Repeat on the back
Step 16:
  • Putting your finger under the colored part of the paper, pull up and squash the model (the same way done to create the Bird Base)
Step 17:
  • Repeat on the other 3 sides of the diamond
Step 18:
  • Carefully unfold the model from the top, pulling out the "petals"
Step 19:
  • OPTIONAL: Use your finger to twist the middle of the flower for an interesting spiral-design. You can also fold back the corners of the petals to look more rounded
Step 20:
Congrats!! You're finished!
