Introduction: Origami Ghost
This is an origami ghost and was so easy to make. It was a lot of fun to do this and everybody will also have fun making this.
A square paper
Step 1: Basic
You would fold the paper vertically, horizontally, and diagonally in both ways. Then you would take the paper in front of you in a diamond form where if you fold it across it would form a triangle. You would take one corner and fold it to the middle, creating a side triangle shown in the above picture.
Step 2: The Body Pt1
You would first hold the paper in a diamond shape with the corner facing you and fold the paper in half and first from the diagonal in the right you would valley fold to form a triangle (the last picture).
Step 3: The Body Pt2
You would flip the paper upside down and open the up flap so it creates a kite and then you would fold it in half so it creates a triangle
Step 4: The Body Pt3
Then you would fold the down half up and flip it around and open the flap and fold the middle in a mountain fold and the rest of the line in a valley form to form the picture in the next step
Step 5: The Body Pt4
You would fold down the first flap to the side at an angle to create an arm and you would flip it around and do it to the other side as well
Step 6: The Arm
Step 7: The Head
You would then fold down the top flap to line it up with the straight line down the arm and open that flap and then mountain fold in the middle and valley fold to the above image and crease it down to the image on the last
Step 8: Head and Arm Shape
You would then fold the flap to line up with the left side of the origami edge and unfold that flap so you can fold it down to create this valley fold inside and it would be the head. You would then fold the arm at a straight line to face the opposite way of the head top and do it to the other side
Step 9: Head Detail
At the corner of the arm, you would fold inside and then at the top of the head fold down the top and open the tip flap and fold inside to create an angle
Step 10: Arm Detail
Do the same to the head as the arm where you fold down and open the flap and fold inside to create the downward form of the arms. Do it to each side
Step 11: Base
Open the bottom of the ghost and fold the paper in the middle at an angle and then fold the side to create this valley fold to cover the back. Then you would restructure the base to make it stand
Step 12: Finish!
Now you are done. Congrats on finishing
