Introduction: Super Easy Origami Pumpkin!
About: Cool Quote: "Creativity is seeing what others see and thinking what no one else ever thought." - Albert Einstein. My favorite quote: "Courage Need Not Be Remembered, For It Is Never Forgotten." - Princess Zeld…
This is my origami pumpkin. It is very easy and fun to make.
My other pumpkin project
Orange paper, Green paper, Scissors and a marker
Step 1: Makeing a Square
With the orange paper, fold one of the top corners down until it touches the edge.
Step 2: Making a Square
Next, cut along the bottom line. Unfold and you have a square.
Step 3: Fold
Fold the square in half both ways.
Step 4: Fold
Next hold two edges that are on opposite sides of each other. Then pull the other edges also. Flatten and you should have a triangle.
Step 5: Fold
Next, grab two edges and fold them up. Then do the same on the other side.
Step 6: Fold
Then fold the outer points to the middle. Repeat on other side
Step 7: Fold
Next you want to fold the top points down into the step 6 fold, there should be a pocket.
Step 8: Inflate
Then look at the top, there should be a hole. Blow into it. The paper should inflate like a balloon.
Step 9: Draw Face
Next find a side that you like and draw a face on it using a marker.
Step 10: Make Stem
Next grab your green paper and cut a small strip out of it. Roll that strip up then put it halfway into the hole. You have a stem!
Step 11: Extra
You can also add a leaf to the stem by cutting out the shape then gluing or taping it on to the stem.
