Introduction: Origami Rose
Hi, first of all if you don’t understand some part please ask
Second well, when you see a photo of this rose it will look Complicated, but believe me is quite easy if you are used with make origami.
please comment
please comment
Step 1: The Paper
For this origami you will need a square of paper, Any kind of paper works, but try to use a Origami paper because its Thinner and it “hold better the fold”, so the rose will look more natural, For this origami I will use a red square of origami paper.
Step 2: The CP
Well this is the Phu Tran rose, an origami that is often folded from the CP (crease pattern), because with it the rose will have less folds, so it will have a better look. Access this site and print the cp
http://www.giftsbeauty.com/imgs/cp.pdf
Step 3: Copy the CP to the Paper
If you are going to use the computer paper, Skip this part.
Copy the Cp on the white side of the paper that you will use to do the rose, use a pen that have the same color of the paper, For example, don’t use a black pen on a white rose PLEASE. Cut the excess of paper
Step 4: Lets Start the Folding
Well let’s start folding, fold the Blue lines with a Valley fold (fold down), and the red lines with a Mountain fold (fold up).
Step 5: Now Your Rose Should Be Looking Like It
Now your rose should be looking like it
Step 6: "Let's 3D It"
Hold your rose like me, and pull the line to the center (like the photos).
Step 7: The Triangle
Now let’s fold the “triangles”
Do this step on the 4 triangles,
Step 8: Lets Do the Rose Shape
Just follow the images
Step 9: Lets Fold the Little Triangle
Step 10: Lets Try to Close It
Follow the images
Do it on the 4 sides
You don’t need to completely close the rose, which is very difficult, because we are going to do a calix for the rose
Step 11: The Result
Step 12: WELL THE ROSE IS DONE LETS DO THE BASE
This one, used in my yellow rose (it was an improvisation, cus I don’t know any proper base for the Phu Tran rose, if you know please tell me)
To do the “yellow rose calix” you need a paper that is 1 quarter of rose paper square size
Step 13: Basic Fold
Fold in a half
And Follow the pictures to make a basic fold
Step 14: The Base
Step 15: Glue Base + Rose
Glue the rose and the Calix, You finished the base let’s do the leaves and the steam
Step 16: Stem
Step 17: Stem + Base
Step 18: LEAVES ( OPTIONAL)
Now for the leaves you will need some paper of the same size used to do the steam, one paper = 2 leaves. Follow the pics (AGAIN )
Step 19: Rose + Base + Steam + Leaves = AWESOME
Well Congratulations now you have a beautiful rose
If you have completed the rose please post an image of the rose and the time that you spent to do the rose (I’m doing a survey about this rose), any doubt JUST ASK. Well this is the end of a 130+ images INSTRUCTABLES, thank you for reading it, bye.
