Introduction: Origami Rose Headband
This instructable shows how to make an origami rose headband
This includes the following
- Making the rose petals
- Making the sepals
- Decorating and assembling the rose on the headband
Step 1: Tools and Materials
- Full size red origami paper (here we use 21 cm x 21 cm )
- 1/4 size green origami paper (11.5 cm x 11.5 cm)
- Headband
- Ribbon (to be glued on the headband)
- Hot glue gun
- School glue
- Super glue
- Scissors
- Tweezers (optional)
Step 2: Find the Reference Point
Fold the 21 cm x 21 cm paper in half.
Then fold it in half again so that you get 4 square shapes. On one of the squares (left one in the photo), fold along the two diagonal lines. The cross point is the reference point to be used in the next step.
Step 3: Cut the Pentagon Shape
Use the reference point we found on step 1 ( point B) , fold the paper so that point A will be on top of point B
Notice that the middle (point C) is not the same as point D
Cut it along the line so that you can get a perfect pentagon shape out of the origami paper.
Step 4: Start Folding the Petals
At the end of previous step, you get a perfect pentagon shaped origami paper.
This pentagon will be the body of the rose.
Grab the pentagon origami paper from the middle, making it stand up like a star.
Notice the yellow line? Fold it from the yellow line. The width of the line actually depends on how you want the rose to feel. In this demonstration, I folded it about 1cm wide.
After you finish folding all five sides, you will get something similar to the 4th photo.
We can now flatten it so that you get a pentagon with folded sides again, as seen in the last picture.
Step 5: First Layer of Petals
Flip the pentagon over.
Now pinch the paper along the lines and swirl-fold the paper.
After you finish all five sides, flip it over again, and you'll have a very basic rose-like flower.
The last photo is from the side.
Step 6: Making the Second Layer of Petals
Pull each side outward and then fold along the line.
Repeat for all five sides.
Step 7: Flip and Fold Each Petal
For each petal, flip and fold it as it demonstrates in the photo.
Step 8: Unfold and Redo
Unfold the flower and re-fold it again along the lines.
At the end of this step, you will have a cylinder shaped rose.
Here is a top view and a side view.
Step 9: Fold Down the Petals
To finish each petal, curl the outer petals tip down.
After finishing all the petals, you'll have a rose.
Here is top view, side view and bottom view.
Step 10: Adjust Each Petal
Adjust each petal to make it look more real.
Here is the top view and bottom view.
Step 11: Making the Calyx
Following step 2 to cut the 1/4 size origami paper to pentagon shape, grab it from the middle and make it into a 5-point star, as seen in the picture above.
Step 12: Continue the Calyx
Flip it to the side.
Fold each sepal along the line and flatten it.
You should see a diamond shape at the end of this step.
Step 13: Continue the Calyx
Fold inward along the lines.
Then flip the sepal upward.
After finishing all 5 sepals, you will get something that looks like the last photo.
Step 14: Continue the Calyx
Follow the line and pull the side out like a pocket
Fold the sepals as line demonstrates.
Finish all five sides.
Adjust it so it looks more life-like.
Step 15: Assembling and Finishing the Headband
After you are finished with the flower and the calyx, glue and wrap the ribbon on the headband.
Use the glue gun to glue the rose on the calyx, and then secure the flower on the headband.
You have an origami rose headband now!
Epilog Challenge 9
Paper Contest 2018
