Introduction: Orite (Weaving Letter)
Season's greetings,thanks, and birthday celebration...What do you send a letter for ?
"Orite" is the weaving letter made of your favorite color, special texture of material, sometimes with sound and fragrance. Orite gives you special time.
Step 1:
For this activity you will need an envelope and thin paper to create a weaved pattern.
First , cut lines on the envelope using a box cutter.
(Using razor cutter would help you make more complex pattern.)
☆The more lines of the envelope, you can make more detailed pattern.
Step 2:
Next, cut paper and make thin slips of your favorite color.
☆At this time, you can use any kind of material.
For example cloth impregnated with perfume!
Step 3:
Then, weave the slips over and under each other and create pattern.
Step 4:
Assemble the envelope by using glue or double-sided tape.
Be sure to stick the slips to the envelope firmly.
I recommend you used double sided tape.
Step 5:
You can create various patterns using this method.
Here is some examples.
