Introduction: Ornate Crochet Flower Rectangle Tablemat
About: Hello all!!!! A warm Welcome and It's a pleasure to have you here. Art and Craft is my passion .I love experimenting new and creative ideas.
Its a good idea to bring a touch of freshness to your Dining Table with Flower Placemats and Tablemats. Crochet Flowers are the perfect way to add a touch of personality to any of your crochet projects. They are great for brightening up your day. You can use them to embellish your crochet projects decorate your home or you can join and make them into Placemats tablemats or Doilies.
Today am sharing the pattern for Ornate Crochet Flower Rectangle Tablemat. Its a Clover Flower Pattern. Its made in a continuous pattern one after the other where the first half of the flower chain is made followed by the upper half. You can easily turn it to any shape you wish to make ,be it a Square or a Rectangle.
I have seen many versions of these flower motif being made. They can be worked individually and can be joined by sewing with a yarn needle. The other way is to only make the center motifs and then finishing off the side motifs. Am sure you will enjoy making this placemat either way.
14 inches - Customizable to any size
Visit https://rajiscrafthobby.blogspot.com/2024/08/ornate-crochet-flower-rectangle-tablemat.html
4 Ply Cotton Knitting Yarn
4 mm Crochet Hook
Step 1:
Round 1:-
Start with a Slip Knot
**Chain 9.
Slip Stitch into the 6th Chain from the hook.(this will make the Ring)
1 Slip Stitch each into the remaining 3 Stitches.(this will make 1 Treble Crochet)
3 Treble Crochets into the Ring.
Chain 4.
Slip Stitch into the ring.(this will make the 5th Treble Crochet - that's total 5 Treble Crochets made in the First Petal)
Chain 4.
4 Treble Crochets into the ring.(this will make the 2nd petal)**
Make sure that each petal has 5 Treble Crochets.
Repeat from ** to ** untill the size needed.
To make the Last Petal:-
Chain 4.
Chain 4.
How to make a Treble Crochet??...here it is.....!!
  1. Yarn over hook twice, insert hook in the Stitch and Pull up a loop.(4 loops on hook).
  2. Yarn over, pull through 2 loops on hook (3 loops remain on hook).
  3. Yarn over, pull through 2 loops on hook (2 loops remain on hook).
  4. Yarn over, pull 2 loops on hook (1 treble crochet complete).
Step 2:
Round 2:-
Chain 4.
Chain 4.
Slip Stitch into the ring.(1st Petal made)
Chain 4.
4 Treble Crochets into the ring.(2nd Petal made)
**Continue working into the next Ring.
4 Treble Crochets into the next ring.
Chain 4.
Chain 4.
4 Treble Crochets into the ring.(2nd Petal made)**
Repeat from ** to ** untill the last Petal.
Chain 4.
Chain 4.
Slip Stitch into the ring and weave off.
Step 3:
Round 3:-
**This Round we will be working from Left to Right.
Join the Yarn into the 4th Chain of the 2nd Petal from Left Side.
Chain 9.
4 Treble Crochets into the Ring.(that's the 1st Petal made)
**In this round the 1st flower will have only 1 Petal.
**Chain 9.
Remove the hook, insert it into the 4th Chain of the 1st Petal of the next flower. Grab the dropped loop with your hook and pull it through the stitch.
Chain 4.
Slip Stitch into the ring.(this will make the 5th Treble Crochet)
Chain 4.
Remove the hook, insert it into the 4th Chain of the 2nd Petal and Grab the dropped loop with your hook and pull it through the stitch.
4 Treble Crochets into the Ring.**
After joining into the last petal ,make 3 Treble Crochets into the Ring.
Chain 4.
Step 4:
Round 4:-
Chain 4.
Chain 4.
Chain 4.
Chain 4.
Chain 4.
Repeat from ** to ** untill the last Flower.
To make the Last Flower:-
** One Petal is already made at the start.
Chain 4.
Slip Stitch into the ring.(2nd Petal made)
Chain 4.
Chain 4.
Slip Stitch into the ring(3rd Petal made)
Chain 4.
Remove the hook, insert it into the 4th Chain of the 1st Petal and Grab the dropped loop with your hook and pull it through the stitch.
Chain 4.
Slip Stitch into the ring and Weave off.
Step 5:
Round 5 Onwards:-
Keep Repeating Round 3 and Round 4  untill the size needed and weave off.
