Introduction: Otto DIY - Build Your Own Robot in One Hour!
Otto is an interactive robot that anyone can make!, Otto walks, dances, makes sounds and avoids obstacles.
Otto is completely open source, Arduino compatible, 3D printable, and with a social impact mission to create an inclusive environment for all kids.
Otto was inspired by another robot instructable BoB the BiPed and programmed using code from another open source biped robot called Zowi.
CC-BY-SA
Otto's differences are in the assembled size (12cm x 7cm x12cm), cleaner integration of components and expressions. Using off the shelf and 3D printed parts, simple electronics connections (almost no welding required), and basic coding skills, you will be able to build your own cute Otto friend in as little as one hour!
Otto is design using Autodesk 123D Design initially and now is owned by Tinkercad software you can modify it for customization or further improvements!
This instructable focuses on how to build the basic Otto DIY version, check the other similar robots in our website and welcome to participate in our #OttoREMIXchallenge
Step 1: List of Parts
Gather all the off the shelf parts that you'll need for this assembly. Here's the list:
1. Nano ATmega328
2. Nano Shield I/O
3. Mini USB cable.
4. Ultrasonic sensor HC-SR04
5. Mini servo SG90 9g x4 (each one should come with 2 M2 pointed screws and one small screw).
6. 5V Buzzer
7. Dupont F/F cable connectors 10cm x6.
8. 4 AA Battery case stacked with switch soldered
9. AA alkaline batteries x4. 1.5V each
10. Mini cross screwdriver. it is important to be magnetized you will se why ;)
And then you only need to 3D print 6 parts in total:
11. 3D printed head.
12. 3D printed body.
13. 3D printed leg x2.
14. 3D printed foot x2.
Optional: cutter for post cleaning the 3D parts (if the 3D print quality is good enough no need) and a soldering iron (if you want it battery power otherwise you can still connect it through USB to energize)
That's all simple!; If you do not have a 3D printer you can always use services or local maker spaces.
If you think is difficult to find the parts, you can buy the full kit here! and follow this video of how to build:
Step 2: 3D Print Settings
Otto is very well designed for 3D printing, the files that you had downloaded are property oriented and centered, so wont give you trouble if you follow this common parameters:
- Recommended to use a FDM 3D printer with PLA material.
- No need supports or rafts at all.
- Resolution: 0.28mm
- Fill density 15%
For slicing and generating the g code for the machine free slicer software like Prusa Slicer(If you are outsourcing the printing no need to worry about it)
After printing you will need to clean a little bit the legs and feet areas that fix the motors.
Step 3: Foot Servos Assembly
Put the micro servo inside feet and then push it inside, if is to hard maybe need to clean more the area with a cutter.
Is very important to check that the servo is able to rotate at least 90 degrees to each side.
After checking the movement use only the small screw to fix it.
Same process for the other foot.
Step 4: Fix Servos to Body
Take the other 2 micro servos put them in the defined locations in the 3D printed body and fix them only with the pointed screws.
Step 5: Fix Legs to Body
Connect the legs to the hub of the micro servo, important like the foot servos you must check the legs are able to rotate 90 degrees each side respect to the body.
After verifying the alignment fix them using the small screws to the hole inside the leg.
Step 6: Fix Foot to Legs
Taking care of the cables as showed in the illustration you should put the cables inside the slots of the body passing thought the hole of the legs.
Once they are in right position use the pointed screws to fix them from the back.
Step 7: Head Assembly
Start from the ultrasound sensor is important to pull out the eyes to the limit.
After putting the Arduino nano in the shield, optionally you can weld the battery holder positive cable to Vin in the board and negative to any GND.
Insert diagonally the both boards together facing the USB conector to the hole in the 3D printed head, then use the last 2 pointed screws to fix it.
Step 8: Electric Connection (Wiring)
Prepare the shield, cables and buzzer.
Then follow the diagram pins numbers and make sure to put them in the right position.
You have at least 4 option to power your Otto:
1. 4xAA alkaline batteries (1.5V each) that connected in series go to Vin pin and Gnd
2. 4xAA rechargeable batteries (1.2V each) that connected in series go to 5V pin and Gnd
3. Just directly from USB cable to your computer or even a power bank
4. External jack connector to use power adapters from 6V up to 12V output
Step 9: Snap the Head and Upload the Code
The head just snaps in, take care of the cables and close it.
For the coding part you will need to install Otto Blockly and just upload any example
Find more robots like Otto in ottodiy.com share photos and videos on facebook or twitter!
PLEASE DO NOT COMMENT IF ANY ISSUE, I don't get notifications by instructables new comments so if anything please post ask in out community directly
3D Printing Contest 2016
Sensors Contest 2016
Robotics Contest 2016
20 People Made This Project!
- ArisBlocky made it!
- iwanestem made it!
- MrArduinoff made it!
- BayuM6 made it!
- JurajR1 made it!
- JonathonT made it!
- DooBiiE92 made it!
- JungE1 made it!
- RamC17 made it!
See 11 More
106 Comments
Question 2 years ago
i need the codes for it plz send the links
Answer 1 year ago
Always here https://github.com/OttoDIY/OttoDIYLib
2 years ago
I have my own 3D printer so all I need is the parts, and I almost have all the parts, except your set of material doesn't seem to include the type, number and size of screws and switch needed. Could you add those details please?
2 years ago on Step 1
Is there a North American or even Canadian vendor to get the "maker kit" from? The delivery timeline of 7-10 weeks is just way too long for me. I'd like to get this for my kid before summer is over.
2 years ago
can i fit a raspberry pi in it so i could make it my voice assistant?
Reply 2 years ago
i guess you can, that would be cool , here we can try to make it https://wikifactory.com/+OttoDIY/forum or please share if you manage.
Question 3 years ago
I finished building Otto, wired him up, uploaded the Smooth Criminal sketch, and turned him on, and all that happens is the legs twitch once, and the speaker makes a ticking sound
I double-checked the wires, I even took him apart and put him back together just to make sure I did it right, but he still just twitches and ticks
Does anybody have any idea what I did wrong ?
Answer 3 years ago
battery low probably
When I try to upload smooth criminal.ino I get the error:
Error compiling to board Aurduino Nano
Does anyone know what this means? THanks!
Answer 3 years ago
is likely lack of libraries or driver
Hello what is the height of BOB ? Thanks !
Answer 3 years ago
not sure you can check by dowloading the thingiverse project
4 years ago
Hi Camilo, You have deleted LedMatrix.zip from latest Github Build but still calling it in Otto.h, which is causing 'Avoid' and other ino files to fail. Pasting lines from otto.h - https://github.com/OttoDIY/DIY/blob/master/librari...
private: LedMatrix ledmatrix; BatReader battery; Oscillator servo[4]; US us;Could you please suggest how best to proceed. 2nd email asking for help
Reply 4 years ago
Did you ever receive a response to this? I'm having the same issue :(
Reply 4 years ago
https://github.com/OttoDIY/DIY/issues/18
Reply 3 years ago
solved ;)
Reply 4 years ago
Hi Suman
sorry i don't check this instructable very often since now all Otto builders are in interacting in the Facebook group, there little issues like this are answer in a matter of seconds.
That Otto.h library was undated, you can check now is fixed
See you in the Otto builder group!
https://www.facebook.com/groups/ottodiy/
Question 4 years ago on Step 2
Hi Camilo,
I had to replace the arduino nano shield(damaged it by accident). Is there something different from the one I got in the kit from ottodiy site(eg. formatting that I am unaware of)? I have been thus unable to get the code to upload properly and unable to get otto to move. Any help would be great.
Answer 4 years ago
Hi Jung
oh that is really sad, but dont worry just get the files from ottodiy.com and you can use in any other Arduino board, next time email me i don't receive notifications from this instructable since was made with other company
4 years ago
HI Camilo,
I get this error while uploading few uno files -
C:\Users\user\Documents\Arduino\libraries\Otto/Otto.h:9:23: fatal error: LedMatrix.h: No such file or directory
#include <LedMatrix.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Nano.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
