Introduction: Tool Trolley From Scrap Metal
This is my custom made Tool trolley cum portable workbench. The whole idea behind building this table is self-inspired & Tool trolley is so much suitable for outdoor Site work & i made this according to my benefits. On site I feel lots of problem & fatigue while repairing vehicles. i cannot carry complete tools in my hand & some time if i need to open some heavy item using bench vice at that time i have to go so far for that & i waste lot of time doing this. Suddenly idea came into my mind for making Tool Trolley cum Portable work bench. The benefits of this trolley is it have lot of storage space with bench vice mounted on it & the size of trolley is 3' X2'.now i enjoyed while repairing things.
one important thing is it is made up of scrap & i spent only 60 $ which is the cost of ply board, wheels, bench vice (old) & the paint.
Step 1: Material & Tool Required.
Seriously, i found 80% of my material in scrap yard.20% only i purchased but if you really want to make this kind of Trolley you will required following material.
1. 2"X2" Scrap angle iron 10 feet
2. 2" Pipe 12 Feet
3. Top Plyboard 3'X2' thickness 1.5"
4. constructional Steel bars 4 Feet
5. 1"X1" angle iron 6 Feet
6. scrap Sheet metal rack
7. Wheels 4 nos
8. 2.5' G.I pipe for Trolley handle bar
9. scrap Bench vise
10.1/2" plyboard 4'X4'
Tools Required
1.Chop Saw
2. Portable Arc welding Machine
3. Drill machine.
4. Measuring Tape
5. Set square
6.Diamond file
7. Hand Grinder
8. Hand saw
i have no circular saw at site so i cut all wood material from hand saw
Step 2: Measure & Cutting of Material.
First of all prepare a rough sketch of Trolley. Then Measure & Mark all material and cut according to desired size. After cutting all material then grind the sharp edges to remove any burr & make chamfer so that weld material can easily filled at the joint & weld joint will be so strong.
Step 3: Welding All Material.
step by step weld the Top angle be careful your angle channel should be 90 degree while welding. Then weld the 2" circular pipes after welding all pipes ensure that your table is in level to check level I used level app in my iPhone. If there may difference in level then it required to grind that side of pipe.
Step 4: Making of Wheel Base & Installation of Wheel
Now it is required to make wheel base so that i can fit wheel for that take 10mm thick plate cut into 4 equal 3"X3" size then according to PCD of wheel plate i drilled 4 hole diameter 5.5mm & Tap with M6 tap in each plate after that weld all the plate with legs of my trolley and installed all 4 wheel with the legs.
Step 5: Bending G.I Pipe for Trolley Handle.
For making Trolley handle i used scrap G.I pipe used for tap connections in home. Bend with the help of Pipe bender then weld that handle on the trolley.
Step 6: Installtion of Drawer & Painting
Luckily I found a scrap Drawer from only I need to change two linear rudder with some lubrication drawer in and out smoothly. Only drawback of this drawer is completely open from 3 side anybody can steal tool.so i covered all sides with the 1/2" ply board.
Step 7: Installation of Plyboard,laminate, Bench Vice, Logo Design & Touchups.
After all welding work has finished I prepare for the laminate installation I choose 1mm thick laminate because it is hard and having good surface finish for metal working. After that I weld strong weld base for bench vise and mount bench vise on that base after that I coat final paint with some touch up & with my GOD sticker it looks good.
Hopes you like..if you like then please vote for me for the contest outdoor structure.
if you required any help feel free to ask.
Regards
Manish Kumar.
