Outside Table From a Car Tyre (tire)
Intro: Outside Table From a Car Tyre (tire)
It also seems my spell checker doesn't like my spelling of 'tyre' - apologies US readers this does of course mean tire!
Materials
Car tyre
Coach bolts I had some left over from building some decking - 200mm x 12mm (8" x 1/2")
Timber top - I used some old slats from a bench my fried had given me a while ago - 3000mm x 50mm x 20mm (~9ft x 2" x 7/8")
Timber shelf/leg support - I used some beech offcuts I had - 1500mm x 50mm x 12mm (~4 1/2ft x 2" x 1/2")
Other timber as needed - I used some pitch pine and oak
Tools
Oscillating multitool - to cut tyre in half. Could maybe use an angle grinder or hacksaw
Table saw / hand saw - I used both
Electric plane / bench plane - I used both
Jigsaw
Screwdriver
Spanner
STEP 1: Cut the Tyre in Half
I couldn't find much on the internet about cutting a tyre in half, mainly how not to do it. Having bought an oscillating tool not long ago it had to be a contender. I used a wood and metal blade as I knew there would be some metal reinforcement in the tyre and hoped the blade would be string enough to cut through them. I started off by marking where I wanted to make my cuts and scored the tyre with the blade so I had a good line to follow. Putting the oscillations on max I started the cut, it was pretty tough going as most of the reinforcement is located near the rim. I found the best way for me was to cut with the tool for a bit and then bend the tyre by hand by the cut which seemed to snap some of the broken steel. After a while I got through this heavily reinforced section the rest of the tyre wasn't too bad. Be warned though the cutting does melt the rubber and produce some fumes so do this bit outside.
STEP 2: Turn the Tyre Inside Out
I had seen tyres that had been turned inside out before, knew it could be done so had a go to see what it looked like. I'm not sure if there is a good way to do this but I used a clamp, my foot and brute force. I tried starting from the middle but that wasn't easy so I tried from the end. I used a clamp to grab the sides and give me a lever then put my foot on the main tyre and wrestled with it until the end was inverted. I then carried on up the tyre until it was completely inside out. Gave it a bit of a clean and dry and brought it inside.
STEP 3: Legs
When I was first thinking of this table as envisaged some kind of wooden legs but having got my tyre in front of me I thought that metal legs would be good and I had some coach bolts left over from building a deck last year. I marked the positions of my legs on the tyre and drilled the holes for the bolts. I used a wood flat drill bit and found that the holes needed to be oversized as the rubber contracted once the holes were drilled. For my 12mm bolts I used a 16mm drill.
Once I had put the bolts through the holes and put the tyre on the ground it was obvious I'd need something to support the legs. I decided to brace it in two directions so cut some wood offcuts, drilled holes in both sides at 45 degrees and put them over the bolts. I then measured for the transverse pieces and glued and nailed it all together.
I put bolts on both sides of the tyre to hold them in position and gives me height adjustment too. I put the wood over the bolts and added the nuts above the wood. After a little tightening and adjustment I was happy with the legs.
STEP 4: Table Top
As I had turned the tyre inside out the tops of the tyres weren't level so I decided to add some supports either end of the tyre to create a level platform, I also added a strip of wood between the two sides to keep it all in place. On top of these platforms I glued and nailed a 25mm x 25mm bit of oak which would bring the underside of the table top level with the highest point of the tyre.
I then cut the wood for the table top from some old bench slats to the same(ish) length and placed them on the top to get a feel for the table. I thought it would be good to mirror the shape of the tyre with the table top ends so marked out some cut lines by eye and cut with a jigsaw. I also cut a couple of pieces to add to the side to hide the internal framework. Once I had cut them all I planed them to remove the top layer (I had originally planned to leave them as they were but the cut ends looked too out of place) and then used a block plane to add a bevel to the edges. The only thing left was to screw the boards down to internal framework.
STEP 5: Finish and Finished
I am very pleased with the outcome and it ended up being better than I had first expected
25 Comments
AshokJ13 7 years ago
Actually i have searching tire cutting tools, all of sudden i see tire tool on your aboe URL so request you to pls. provide me tire cutting tool make and technical details on my mail id. ashok.dpr@gamil.com
RamziS4 7 years ago
See this video How to Recycle your old Tire into a DIY Golden Table
p2plus 10 years ago
Love my new table ;-)
thanks a lot !
petachock 10 years ago
Did you make one of these? nice one! if you have a photo it would be great to see it.
BiffIsGod 10 years ago
Vampyra65 10 years ago
This is cool. I've been looking for great ideas for used tires. I might even paint mine and try to sell them.
diogo007 10 years ago
Nice instructable! It would be a good idea to drill a hole on the bottom of the tire, to avoid mosquitoes in case any water is retained on the bottom of the tire.
Money_Illusion 10 years ago
What a wonderful idea. I think I'll give this a try one weekend. I have a few tires that I planned to discard plus 2 large tractor tires. Not sure if I can invert those 2 beasts. I think also I'd like to add 2 small tires to the legs from a left over lawn mover to make it portable and a handle up top.
terihens 10 years ago
skubaduk 10 years ago
Cutting most tires is fairly easy. I have cut them with a handsaw, then used a hacksaw to cut through the bead. Now use, Sawzall type tool, should probably use a bi-metal blade. Circular saw
jrdelrey 10 years ago
Nice way of recycle, I also thought in using recycled wood from pallets so we are a bit more ecofriendly
kcox18 10 years ago
MEEEEEEEEEEEEEEEEEEEE 10 years ago
COMPLICATING!
onemoroni1 10 years ago
Great idea to re-purpose an indestructible tire. I can see many variations using the basic idea.
l8nite 10 years ago
great concept and a fantastic carry through !
bonsaiknitterguy 10 years ago
Kiteman 10 years ago
+1 on the drainage holes. A two-minute job with a drill and a twist-bit.
YES! I had thought of that but hadn't got round to it, was supposed to add it to the instructable too!!!
