Introduction: P9C - Chair Made With CNC Router
CNC Furniture has been for a few years already but hasn't really taken off. I believe this is because designers haven't spend enough time designing with that technology in mind. Most of the CNC furniture I found online have the typical joinery exposed or have a rigid feel. I played around with the ShopBot Buddy (worktable 4' x 2') and made a family of chairs: Lounge Chair, a Stool and this Dining Chair. I wanted to design a modern chair that would have a retro look, similar to a school chair but making it more ergonomic and comfortable.
CNC Routers have become affordable in the last couple of years and there are quite a lot of DIY CNC Routers out there. If you have a TechShop close by you can probably make it over there.
Step 1: Materials
Materials:
- ¾ inch pre-finished maple plywood (2 sheets 4'x2')
- Shopbot
- ¼ inch End Mill
- Wood Clamps
- Wood Glue
IMPORTANT: measure the thickness of your plywood! I purchased the white melamine plywood in 0.75” thick (19.05 mm) but as you can see from the photo, the it was 19.81 mm and the pre-finished walnut was 18.95 mm thick. This is really important to take note because the design has locking parts and we need to accommodate for a thicker material.
Step 2: Design and Prepare Vector Work
I used Rhino to design the chair as I've been using it for the last 10 years. I took some measurements from other chairs to have a sense of what the overall dimensions, specially the height, angle and width. You can edit the files as you wish and make a custom version for your own.
My biggest design constraint was that at least one leg had to fit in a 4' x 2' plywood sheet (that was how big my working table on the ShopBot is). I was able to make it fit on the sheet by rotating it a little, if you have a bigger working table you don't need to do this and probably have a more efficient use of material. You can download the Rhino file and STL to play around and edit the design. Once I had all the flat pieces I arranged them in 4’ x 2’ sheets. Download the illustrator or Autocad file that you will need to create the toolpaths.
As you can see from the 2nd image, the stool fits in 1.5 sheets of 4' x 2' plywood (that was how big my working table on the ShopBot is) and it is very fast to cut and assemble. You can download the Rhino file and STL to play around and edit the design. Once I had all the flat pieces I arranged them in 4’ x 2’ sheets. Download the illustrator or Autocad file that you will need to create the toolpaths.
Note on woodgrain direction: This is an aesthetics warning. The orientation you give to every piece will matter once they are put together. For example, it is nice to have the seat or the seat rest match in orientation because the wood grain will be continuous. The seat is composed by 3 pieces and it will look inelegant if each one has the wood grain going in different directions.
Files included:
- chair.3dm - Rhino CAD drawing
- chair.stl - for a 3D preview
- chair.dwg - Autocad vector in mm.
- chair.ai - Illustrator vectors in mm.
Step 3: PartWorks: Creating Toolpaths
Create a New File.
Now in Job Setup: We will create a file with the size of our material: 4' x 2' x 1/4" (or how thick your true material is). Zero on the top.
Import Vectors files and your vectors will appear on your sheet. Sometimes your vectors might be outside the sheet so will need to zoom out.
Another thing you need to do is actually joining open vectors, under the section Edit Vectors. Control+A will select all of the vectors and then hit the Join button. Hit the Join button again.
If you need to correct or move some objects around the sheet now is the time to do it. You might want to do this to optimize material.
Control + A (select all), click on the right tab: Toolpaths (pin it so you have it open for the rest of your session).
POCKET TOOLPATH:
Under the Toolpath Operations you will see a few options. We will begin with Pocket Toolpath that will clear an area as deep as we want. You should always start with pockets because all of your material will be in place - for example, if you start with a Profile cut and your piece moved because you didn't have tabs (or they were too thin) you will have a loose part and your pocket will be made in the wrong place.
Select your vectors that we want to pocket. These are all the small closed vectors that look like a dogbone and they are inside the cut pieces.
Click on “Toolpath” tab on right side of screen. Under “Toolpath Operations” select “Create Pocket toolpath.”
Start Depth: 0” (starting on top of material)
Cut depth: Choose a finished depth of cut which will be less than 3/4 ". I used 0.551" but if you want to change it you will also need to change the dimensions of the part that fits inside.
Now you need to select the Toolbit you will be cutting with. Under Tool, click on Select and use a 1/4 inch End Mill
We are going to select Offset that will follows the contour of the design. Select Climb.
PROFILE TOOLPATH:
The 3rd icon is for Profile cut and a fill in sheet will appear with options. The first set of values will determine how deep you want to make the cut. Our start depth will be zero since we zeroed on the top of the surface. You want to cut all the material and a tiny bit of the sacrificial board so add a little depth to your Cut Depth (C).
Now you need to select the Toolbit you will be cutting with. Click on Select and use a 1/4 inch End Mill
Since we are cutting the pieces mark on Machine Vectors: Outside/Right.
Add Ramps to Toolpath, Smooth, pick a Distance (4-6 inches works well).
Save Toolpaths: You will be prompted a "WARNING - Tool will cut through material" but you know that already because you did that on purpose when you selected the cutting depth. Once you succesfully created the toolpaths you will see a preview. Once you are satisfied with what you see, hit Close.
Make sure you select Pocket1 and Profile1 and hit Save Toolpaths, it will have an extension SBP.
NOTE ON CREATING TABS: Tabs are pieces of your material that won't be cut to hold the parts in place. Since I had quite a lot of parts to cut and I didn't want to do a lot of post-processing work I decided NOT TO MAKE TABS. If you have a worktable with vacuum then this is great because you won't need tabs anyway.
Step 4: Receiving Material and Cutting It Down
I ordered my plywood from MacBeath Hardwood and they delivered to our shop at Pier 9. Full sheets are 8' x 4' so you need to cut them down to 4' x 2' to make them fit on our Shopbot Buddy. We didn't have a panel saw so I cut them with another person and a table saw.
Step 5: Zero X, Y and Z Axis
Now you are ready to cut the pieces for your table. Place your 4’ x 2’ sheet of ¾ plywood on the worktable of the Shopbot. Use screws to get the sheet down to the table.
Turn on the Shopbot and the Computer. Open the Shopbot manager. Put the ¼ inch End Mill on the Collet and you are ready to Zero the machine in 3 axis.
Use the proxy switches to Zero both X and Y Axis. Now use the Z plate to zero the Z axis of the Machine.
Zero Z Axis with Z Plate:
- Cuts - C2: Zero Z Axis w/Zero Plate
- It will prompt if we have the Zero Plate bellow our bit. Hit Enter when ready.
- It will now go down, touch the plate, go up and then slowly go down again to touch the plate one more time.
- It will prompt that it has been zeroed. Awesome, now you are ready to begin the cuts!
Step 6: Run Toolpath File
Open your Toolpath file and hit Start. You will be prompted a Warning message to start your Router/Spindle. Make sure you actually start the spindle before hitting OK on the Warning message.
The Shopbot will now begin to make the cuts on your material.
Step 7: Watch and Remove Parts
Now this is the easy and fun part. You sit down next to the router and watch how the machine cuts all of your pieces. Since I was using a ¼ inch End Mill it will make 3 passes before it actually cuts loose each single part. It will start by doing the pockets and then the profile cut.
Remember that we didn’t add tabs so if your pieces are really close to each other it might be a good thing to take your recently cut piece out of the table. I did this easily without stopping the machine.
Once the job is done the Spindle will turn off automatically and you can unscrew your material off the worktable. For a single lounge chair 2 sheets of 4’ x 2’ is needed so now go ahead and repeat the process for the 2nd sheet.
Step 8: Minor Adjustments
As I mentioned earlier it is a really good idea to measure the thickness of the plywood. I wasn't really good with my measurements and I found out that my pockets were too tight for my joint so I had to peel the melamine away to make it fit. I did this by marking it with a knife and then peeling it out as you would peel an apple.
Another adjustment I did was that I really didn't have a smooth edge on some areas and sand it down with an orbital sander.
Step 9: Organize Parts
We have a bunch of pieces and it is a good idea to organize them before we begin to assemble. We should have:
- 2 legs
- 2 supports between each leg
- 3 seat parts
- 3 backrest parts
- 2 joinery parts
Step 10: Assemble Seat
Now it is time to start assembling the pieces together. I started by gluing the the seat and moved on to other parts while it was drying.
Glue the 2 supports to the seat. Be real careful because the supports have different lengths. The longest support should be glued to the pocket closest to the edge (look at the first image). Clamp it nice and firm. Move on to the next step while you let it dry.
Step 11: Assemble Legs
Nos assemble the left leg with the left seat. I used 2 clamps to hold it firm in place and then did the same with the right leg. Leave the clamps for 30-60 minutes.
Step 12: Assemble Backrest
The backrest is composed by 3 parts. We will begin with the side sections and leave the middle part for later. Glue the side parts to the joinery section (the long tab).
Step 13: Assemble Backrest With Leg
Now assemble the 2 backrest sides to the leg.
Step 14: Assemble Legs to Seat
Once is the seat is dry you can take of the clamps and glue the seat to the legs. Use clamps again to make a firm joinery.
Step 15: Glue Middle Backrest and Remove Clamps
Now assemble the final piece, glue the pockets and use clamps again. Let it dry overnight and you are done!
Step 16: Enjoy!
Now it's time to sit down, relax and enjoy your P9C Chair!
Step 17: Next Step: Complete the Set!
If you enjoyed making this chair you should check the other 2 products from this family: the P9L Lounge Chair and the P9S Stool.
18 Comments
1 year ago
Hello ! I would really like to make this chair in my fablab,
unfortunately I cannot open either .ai nor .dwg files. Could you maybe
upload a .dxf, .pdf, or .svg file ? It would be heaven !! :)
2 years ago
I would love to download the .3dm file, but it appears to be corrupted. Has anyone else had issues with it?
Question 2 years ago on Step 2
Hi, I really love your chair. I want to make a pair but I have a XCarve and the only files I can import are SVG and DXF. I converted your files but I want to make sure the measures are fine.
Also the cuts are on the line or inside/outside.
Thank you so much.
Question 3 years ago on Step 17
I Love the P9C Chair and i can not wait to build 4 of these beautiful chairs for the front deck, can you please email the dxf files, very much appreciated, Peter@cygnetcncdesigns.com.au
4 years ago
Hi Very Cool. If possible can you send the CAD drawings, Love to use as an example of CNC use for students. Thanks in advance jasontheblacksheep@hotmail.com
Reply 4 years ago
Just login and download the files from the instructable.
6 years ago
Anyone have any problems with the distance between the back leg pocket and the cut above it where the leg meets the seat? Trying to cut this now but the shop teacher is saying its too close.
7 years ago
Did you design a dining table to match the chairs yet? Would love a full set...
7 years ago
Is this chair comfortable? Looks like the back rest is quite low? And maybe it should be more straight up. I mean the angle. It looks very good though!!
Reply 7 years ago
Make it and try it out. If you don't like it, change the angle. All of the files are online.
7 years ago
This looks awesome but cannot find the files needed for the machine. Can someone please email me those? Would be great! Thanks in advance. Emailadress is b.vo@live.nl
8 years ago
Hi. I love your chair. Could you send me a copy of the cad drawings? I live in Merida, Mexico and would love to enjoy this chair. jorge.lire@gmail.com
9 years ago on Introduction
extremelly nice design
it is use cnc router 5aixs ? http://www.sinomac-cnc.com
9 years ago
Awesome! I wish I had a CNC router. Very inspirational
Thanks! Are you close to a Techshop?
Reply 9 years ago
Sorry for such a late reply. I live in Portugal. We do not have Techshop here! But I found a guy with a homemade one!
Awesome! Hope you can build a few of these chairs. I'd love to see them!
