Introduction: PATT-28v1.7
Here are the instructions for my pump action gun.
Step 1: Pieces
Rods
-5 grey
-4 red
-1 yellow
-11 blue
-43 white
-96 green
Connectors
-13 white
-14 blue
-52 yellow
-8 green
-21 red
-3 light gray
-12 dark grey
-21 orange
-2 decapitated dark grays or one cut in half orange.
Miscellaneous
-12 Y-clips
-8 blue metallic end caps
-5 tan end caps
-2 thin rubber bands
- 1 or two thick rubber bands
-5 grey
-4 red
-1 yellow
-11 blue
-43 white
-96 green
Connectors
-13 white
-14 blue
-52 yellow
-8 green
-21 red
-3 light gray
-12 dark grey
-21 orange
Miscellaneous
-12 Y-clips
-5 tan end caps
Step 2: Barrel
Here's the barrel.
1:Make
2:Make
3:Connect
4:Connect
5:Make
6:Add
1:Make
2:Make
3:Connect
4:Connect
5:Make
6:Add
Step 3: Magazine
1:Make
2:Make
3:Connect
2:Make
3:Connect
Step 4: Pump and Firing Pin
1:Make
2:Add
3:Make
4:Add
5:Make
6:Add
2:Add
3:Make
4:Add
5:Make
6:Add
Step 5: Trigger
1:Make
2:Make
3:Make
4:Connect
5:Connect
2:Make
3:Make
4:Connect
5:Connect
Step 6: Body
1:Make
2:Make
3:Connect
4:Make
5:Add
6:Add blue rod
2:Make
3:Connect
4:Make
5:Add
6:Add blue rod
Step 7: Handle
1-2:Make
3:Add
3:Add
Step 8: Connect
1:Gather all sections
2:Connect handle and body
3:Connect body and barrel
4:Connect mag to barrel and body
5:Add trigger
6:Add Firing Pin and pump. (To add the firing pin push it in hard at the bottom of the hole)
7:DONE!
5:Add trigger
7:DONE!
Step 9: Add Rubberbands and Loading/Firing
Just Kidding.
1:Get rubber bands, should be two thin ones.
2:Stretch Firing pin rubber band from here...
3:....To here
4:Block Rubber band
5:Pusher and rubber band
6:Add 10 blue rods and the pusher and attach rubber band like this.
3:....To here
4:Block Rubber band
Step 10: My Other Guns
Check out my other guns,
Knex Chainsaw Gun
True Bolt Action Sniper: BAS-39v3.5
DD-27 Pistolv2.1
My latest gun: BMSS-62v2.3
Knex Chainsaw Gun
DD-27 Pistolv2.1
