PC Construction How To
Intro: PC Construction How To
Gather all you Components!
Mother board
Graphics card
CPU
Video card
RAM
Hard drive
Power supply
Case
CPU fan
SATA cable
Thermal paste
You should a build your own computer because it is much cheaper than buying a prebuilt machine and it teaches you valuable skills on how to problem solve. It also teaches you about how computers work.
STEP 1: Work Space Steps
Clear a work space
make sure your work space is not damp, prone to static shock or dusty
the more space you have the better
place down an anti static mat or wear an anti static armband
place Components within reach of work space
ensure you are not wearing any polyester or silk that may cause unwanted static electricity
STEP 2: CPU Installation
Place your mother board in your work space
(optional place on top of a box)
unhinge the CPU latch
(AMD) ensure the pins on your mother board are not bent
pick up your CPU by the edges
(Intel) ensure the pins on CPU are not bent
align the CPU with your motherboard
gently drop the CPU into the motherboard
close the latch on the CPU
STEP 3: CPU Fan Installation
spread a thin layer of thermal paste on your CPU
pick up your CPU fan
align you CPU fan with the motherboard
Place CPU fan on clamps
Clamp down the lever on your clamps
plug in your CPU fan to your mother board
STEP 4: Ram
RAM:
Align your ram so it fit in the slot
choose the slots closest to your CPU
Place your ram in your slot(s)
STEP 5: Case
unscrew the lid of your case
use the Stilt screws in your case where you plan to place the mother board
place mother board with all components in your case
Screw your mother board on to the stilt screws
plug in all the cords in the case to the mother board
there are all lined one one side of your motherboard beneath the Video card slot
these cord's positions varies depending on the Motherboard so check the labeling on the Mother board
list of cords:
Power SW
Reset
HD lED
USB cord
HD audio cord
STEP 6: Video Card
Align your video card so that it is visible from the backside of the case
press down on the video card until it snaps into the slot
place in your motherboard screw in the top of the Graphics card to the case
STEP 7: Hard Drive
find the shelves located in the bottom front end of the case
ensure that the Sata cables and power cables are facing the power supply.
Slide the hard drive onto the shelves
lock the hard drive using the lock that should come with the case
(otherwise use screws)
plug in the Sata cables to the hard drive and the mother board
plug in the power supply to the hard drive
STEP 8: Power Supply
Align the power supply so the power outlet is facing the slot leading outside the case
place the power supply in the bottom of the case
screw in the power supply
attach the ATX one way cord located near the RAM
attach the ATX one way 12 volt cord located near the VGA and USB imputs
there is only one way to attach these cords
(don't forget forget to plug in the hard drive power cord)
6 Comments
vina1991 8 years ago
i like your effort to make tutorial about custom pc building :) .but i found so many mistakes or misleading informations
1) use golden triangle to align the cpu with socket
2) you don't need thermal paste if your using new components.just because a layer of thermal past is already in the heat sink
3) to fix the ram you need to use little bit force at both ends
4) you must connect 24-pin + 4 pin 12V connector and 4 pin CPU connecter
wold630 8 years ago
What do you think your estimated cost was?
123Voeux 8 years ago
Price depend on what you want.
Wolfbane221 8 years ago
Nice short instructable though! I think a parts list with a estimated cost would add to its value.
Murray Locksmith 8 years ago
My Goodness.
Lords_Army_Mil_Club-MILSIM_TEAM 8 years ago
That is the thing about PC Building, there is no specific price. It could be from about $350-$10,000, depending on what you want.
