Introduction: POLICE LIGHTS WITH VARIATION OF SPEED
About: designer of circuits and professional electronic projects www.pcbway.com
We will make an intermittent circuit with the CI NE555 and we will see the sequence of lights like the police lights
Step 1: SCHEMATIC DIAGRAM
Like all my projects, I share the schematic diagram so that you can do it yourself. The schematic diagram was designed in EASYEDA, a very professional and free electronic circuit design software, we can observe the electronic components that we use for this project and their respective values.Like all my projects, I share the schematic diagram so that you can do it yourself. The schematic diagram was designed in EASYEDA, a very professional and free electronic circuit design software, we can observe the electronic components that we use for this project and their respective values.
Step 2: FUNCTIONING
This circuit provides voltage pulses that will turn the LED on and off indefinitely. The function of the integrated 555 is clock or CLOCK, that is, it is the component that generates the voltage pulses.
The frequency or speed of the pulses produced by the integrated circuit 555 depends on the values ​​of the resistors R1 and R2 and the capacitor C1.
When pin 3 of the IC is LOW or zero volts, current flows from the positive to the LED, to the resistor, and then to the negative of pin 3. Therefore the LED is turned on.
When pin 3 of the IC is HIGH, no current flows through the LED diode because it has two high voltages across the LED diode and resistor R3. Therefore the LED diode turns off.
So what function does a 555 integrated circuit fulfill?
The 555 integrated circuit is used as a timer, pulse generator, or oscillations. It can also be used as a flip-flop integrated circuit.
Step 3: ELECTRONIC COMPONENTS
  • 9 RESISTORS 1/4W 100ohms
  • 2 RESISTORS 1/4W 1K
  • 1 CI NE555
  • 1 500K POTENTIOMETER
  • 1 CAPACITOR ELECTROLITO 100uF 50V
  • 1 CAPACITOR ELECTROLITO 10uF 50V
  • 1 JACK DC
  • 16 DIODES LEDS 5MM RED
  • 16 DIODES LEDS 5MM BLUE
  • 2 TRANSISTORS 2N2222A
  • 1 PCB
Step 4: FEATURE
  • VIN 12VDC
  • I MAX 100mA
  • SPEED VARIATION
  • BLINKING LIGHTS
  • HIGH OUTPUT FREQUENCY
Step 5: EASYEDA
The following project was carried out in the PROTEUS software, we can observe its connection paths and its 3D image
Step 6: PCBWay
PCBWAY has 10 years in the electronics industry manufacturing professional PCBs, assembling PCBs managing to satisfy the demands of all parts of the world, in addition to meeting the highest quality and delivery time standards. PCBWAY allows the manufacture of your PCBs from 5 units.
This project was carried out thanks to PCBWAY, a company dedicated to the manufacture of prototypes and professional PCBs, in addition to offering you a ready assembly service with all the components in your PCBS, complying with the established quality and delivery time standards.
We thank PCBWAY, a leading company for manufacturing and assembling professional PCBs with the highest quality, PCBWAY has fair reasonable prices, punctual shipping time and 24-hour customer service, it also offers you the option of quoting all its services in his web page. Do not think twice and start manufacturing your professional PCBs from 5 units safely.
10pcbs at $5 order them here www.pcbway.com
We thank PCBWAY for the professional pcb they provide us for this project.
GERBER PCB:
https://mega.nz/file/yQwjEJzT#y0PEId3VH2Qp5NCrYUPhW9UnNQFEDj1gXFnchrmaw8Y
