Introduction: POV Bike Display - ESP8266 + APA102
**DISCLAIMER**
This instructable was part of my master's thesis and is by any means finished. I don't have a workspace at the moment, so I can't finish it before I got a proper space to test and build.
If you would like to build a POV bike display feel free to use this as inspiration, but I would recommend you to use the Adafruit guide.
How to turn your bike into a moveable screen in the city? This instructables aims to answer how to do that cheap and easy with parts most makers already have lying around.
Before we start on how to build the device I would like to thank Ada and her guide on making a POV display. I have used the code from her guide as inspiration, a stepping stone and a huge part of her code exists in my example.
The biggest difference is that I have made the code work with the popular WiFi microprocesser, ESP8266. I'm using a NodeMCU v2 in my example which required a lot of tweaking. My main reasoning behind choosing an ESP8266 device is that it is a powerful piece of hardware, and you can implement wireless communication to control the image, synchronize multiple units or whatever you can come up with. Another difference is that I have implemented an image stabilizer that should make the screen more readable when riding the bike (there is a lot room for improvement but if you want a finished and professional consumer product buy POV from Monkeylectric). The last difference is that I'm using cheaper parts in my build. The SK9822/APA102 is basically the same hardware as Adafruit Dotstar but way cheaper. You can get a NodeMCU for only $3.95 if you can wait for it to ship. And now to the guide!!
Step 1: Components
For this build you will need
- 1x NodeMcu v2
- 1x APA102 led strip at least 32 pixel
- 1x APA102 booster pixel
- 1x Reed switch
- 1x Magnet
- 1x 10k ohm resistor
- 1x 3 AA battery clip
- 3x AA batteries
- 1x SPST switch
- 1x 1000uf capacitor
As mentioned above, I chose this microprocessor for various reasons. It is fast, cheap, small, and potential for wireless communication.
These LEDs are super fast and great for projects where timing is a critical factor. Compared to another popular choice WS8212/neopixel it got a clock pin to secure that it doesn't go off sync. You can also opt for APA102 clones called SK9822. You can split up the strip and both parts are still functional because each pixel got a driver, so when you buy a meter of LEDs for your POV project, the rest can be used for the other wheel of the bike or another project.
Booster pixel:
You need a single APA102 pixel (cut it off at the end of your strip) as close to your NodeMCU as possible. The reason is that the NodeMCU only outputs 3.3 volts and the APA102 operates at 5 volts but if you put a pixel close enough, it works as a Logic Level Converter, so the clock and data signal gets converted to 5v to the rest of the pixels. In the code we never send color to the booster pixel as its only function is to amp the signal, so we don't need to have the strip close to the NodeMCU. I would like to give a thank to Elec-tron.org for coming up with the idea.
Reed Switch and magnet:
The reed switch gives a pulse every time it passes the magnet, and I'm using this for stabilizing the image while riding the bike. I don't have a link for where i bought this, because i found it in an old magnetic cat door in an electronics dumpster. We are using the 10k ohm resistor as a pull-down to minimize noise.
The rest:
The capacitor is preventing voltage drop when the strip goes from no color to (as an example) all white.
The batteries only provides 4.5 volts but it's more than enough to drive the system.
The SPST switch is used to turn the circuit on and off.
PS: some APA102 versions have switched between red and green pin. If you have a GRB instead of RGB your strip flash green when you write red to it. I have used both, so that's why some of my pictures on github looks weird.
Step 2: The Circuit
I've made the mistake of making long wires from the NodeMCU to the booster pixel in the diagram. It is VERY important to make those wires as short as possible. The distance from booster to the rest of the pixels can be as long as needed. In the diagram and in my version I have placed the capacitor close to the power supply. I would rather place it close to the pixels but both works fine.
Step 3: Soldering
Step 4: Assembling and Attach to the Wheel
I have made my version into a small package and attached it with a combination of zip ties and duct tape. I would recommend another way to do this because it's not very practical.
If you want to stabilize the wheel you can attach a second battery pack (in parallel with the first one, circuit wise) on the opposite side.
The magnet is attached to the frame of the bike with hot glue so it aligns with the hall sensor when the wheel rotates.
Step 5: Sketching Images and Concepts
This step consists of making concepts and sketching the image for the bike.
As you can see in the photos this can be done with friends and it might help you to come up with something interesting for your bike wheel. It really helped me/us to discuss our ideas with each other to frame and reframe the message we wanted to send. Remember if you install this it's not only for you to look at, but everyone you meet on your way. Think of the route you normally take your bike, is there something along that way you want to comment on?
I've made a template that might help you coming up with a subject and to design your bike wheel
Step 6: Making Images
Now it's time go to photoshop or another image editing program. My images are 84 by 32 pixels because I have 32 pixels in my LED strip and I found that 84 was a good length. You can play around with the width of the photo to find a size that creates the best picture on your bike
When you display your images on your bike it will be stretched in to top of the images and squeezed together at the bottom.
The first four images wont be displayed very well on the wheel and are concept photos that need to be warped to make it fit the POV display better. The last image was used to make the featured image of this instructable and have the right dimensions and is warped to be more readable.
Depending on how you turn your bike and/or on which site you put the leds, you might have to flip the digital image vertically and/or horizontally.
Step 7: Code
My code can be found on my github.
Microcontroller Contest 2017
15 Comments
3 years ago
Hi , so if i want to use 4 LED strips aranged in a cross on my wheel , how should i do?
5 years ago on Step 7
Great project, shame about the politics. Expect four more years in 2020 with that attitude!
Reply 5 years ago
Can I get you to elaborate why you think it's a shame about the politics?
I suspect that you might misread my intentions :)
5 years ago
Hello!
This is a great project. I got into a little bit of trouble...When I turn it on it works-got a bar of leds in blue and yellow which are changing in approx 1second interval. reed switch doesn't react so I'm a bit confused.....
5 years ago
Hi, what an awesome instructable and by far the simplest to implement POV project! Thanks for sharing!
I'm trying to build one to spin continuous on a motor and i'm trying to figure how to modify the code for it to refresh itself a number of Hz instead of reading the trigger from the reed switch, but this is all a puzzling mess to me! Would you have any advise or know how to do so? Hope you could share with everyone here, I'll be so grateful :-) Again, AWESOME project!
Reply 5 years ago
I'm trying to do the same. Do you have any solution already?
5 years ago
Tnx
Learning to create a link to the device and teach the coding
6 years ago
Friend, I do not know much about programming, can you do a more detailed tutorial?
6 years ago
These are awesome :) I love how versatile these displays are!
Reply 6 years ago
Thank you :)
6 years ago
Nice work! Do you have any video of the wheel in action?
Reply 6 years ago
I have some but it's difficult to capture properly with smartphones and DSLRs because of the difference between the human frame rate and camera. Thought about installing magic lantern on my camera to make a more "real life" video of it, but it's part of my master thesis and it's writing time (maybe after I hand it in).
This is from the first iteration of the project https://www.instagram.com/p/BNMUd6EjEvF/?taken-by=...
In the future I would like to add more strips/LEDs, so it's easier to see the image at lower speeds :)
Reply 6 years ago
I see the challenge now. Thanks for sharing the video anyway, still looks awesome. Also thanks for the tip on magic lantern, I had never heard of it.
6 years ago
how to make this?
6 years ago
awesome! i want.
