Introduction: PU Wheel Friction Drive E-Bike
This is a friction drive system I designed that uses PU wheel electric skateboard hub motor. I'm using SONY VTC6 18650 6S2P batteries(22.2v 6000MAH), got a top speed of 15km/hr on flat ground. Plan on doing some more tests with higher voltage batteries.
STL files: https://www.thingiverse.com/thing:2556492
Step 1: Prepare Parts Needed for the Build
Parts
- Motor : https://amzn.to/2UXlez3
- VESC : https://amzn.to/2GZC4th or https://amzn.to/2GZC4th
- Throttle Grip : https://amzn.to/2H1r5Q7
- Arduino for Analog to PWM converting : https://amzn.to/2H1Ro92
- Screws :
1pcs M8 x 60mm bolt
3pcs M4 x 25mm bolts
3pcs M4 x 35mm bolts
3pcs M4 nyloc nuts
- Battery : SONY VTC6 18650 6S2P (22.2v 6000MAH)
