Introduction: PUBG Theme Song +animations With OLED & Arduino
Hello there and welcome to this fun instructable! I hope all of you are well and staying healthy. This small but amazing project is about playing the PUBG theme song and even creating some game animations using arduino.
The components used are very easily available and very easy to assemble on a piece of breadboard. I will be sharing the entire building and coding process in this instructable, stick around till the end! I would highly suggest you watch the video to get an idea of the project :) If you like it then like and share the video. Consider subscribing to my channel if you enjoy my build.Thanks! So, without any further delay, let's get started!
Step 1: Gathering All the Parts
The build mainly consists of an Arduino UNO which is the main core for this project. You can use any other Arduino variants like the popular Arduino NANO, Arduino Pro Mini, Arduino Mega etc. To display the animations and the images, I decided to go with a 0.96 inch OLED display with a resolution of 128 by 64 pixels. This display can be interfaces with the arduino with the I2C protocol that requires just two wires for data and clock,thus reducing the number of connections and making the project more compact. For playing the PUBG theme melody I used a 5V buzzer of which I connected the positive pin with digital pin 6 of arduino and ground goes to ground of Arduino.
These are the list of parts needed for the project :
  1. Arduino UNO (or any other arduino board of your choice )
  2. 0.96 Inch OLED display module
  3. 5V buzzer
  4. Jumper wires
  5. Breadboard
  6. Arduino programming cable
Step 2: Connecting Up the Oled
A total of 4 connections are needed for the OLED display to be connected from arduino:
  1. Vcc --> 5V of Arduino
  2. Gnd --> Gnd of Arduino
  3. SDA --> A4 of Arduino
  4. SCK --> A5 of Arduino
  5. Pins A4 and A5 of the arduino serves multiple purpose of analog inputs as well as pins for I2C communication. Here we have utilized the pins for the I2C protocol for interfacing with the display module. The link to the Adafruit library used in this project : https://github.com/adafruit/Adafruit_SSD1306
Step 3: Connecting the Buzzer
The 5V buzzer has a positive and negative supply terminal.
  1. Positive pin--> D6 of Arduino(digital pin 6)(you can use any digital pin of the arduino)
  2. Negative pin--> Gnd of Arduino We are going to create the desired tone on digital pin D6 to which the buzzer will play the melody.
Step 4: All Hardware Connection
All the necessary connections of OLED display and the buzzer are complete. Now let's go ahead to understand the programming aspect of the project..
Step 5: Resizing Image and Bitmap Code
Now, the interesting part of the project is the process to convert an image to a bitmap array for the OLED display according to it's pixel density. For this I found the prefect online tool that allows us to generate the custom bitmaps.
The link for this online application is :
https://diyusthad.com/image2cpp
Thanks to the amazing creators of this application, this makes my work much easier. Upon going to the link you first have to upload the image you want to create the bitmap of. One thing to note here is you should try to select images that do not have a lot of color contrast in it, try sticking to images with a few solid colors,without any gradients to get better results
Step 6: The Entire Code
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(128, 64, &Wire, OLED_RESET);
static const uint8_t  PROGMEM image_data_20190410_114707[] = {
// 'pubg1 (1)', 128x64px
// 'pubgfigure (1)', 128x64px
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xff, 0xff,
0xff, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff,
0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff,
0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff,
0xff, 0xfe, 0x00, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xe0, 0xe0, 0x03, 0xff,
0xff, 0xfc, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x81, 0xff,
0xff, 0xf8, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0xff,
0xff, 0xe0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x7f,
0xff, 0xc0, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x3f,
0xff, 0x80, 0x3f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xc0, 0x1f,
0xff, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe0, 0x1f,
0xfe, 0x00, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe0, 0x0f,
0xfc, 0x01, 0xff, 0x00, 0xfe, 0x00, 0x40, 0x00, 0x00, 0x7f, 0x00, 0x1f, 0xc0, 0x0f, 0xf8, 0x07,
0xfc, 0x03, 0xff, 0x07, 0xff, 0xf3, 0xf0, 0x3e, 0x03, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xfc, 0x03,
0xfc, 0x03, 0xff, 0x0f, 0xff, 0xff, 0xf0, 0x7f, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xfc, 0x03,
0xfe, 0x01, 0xff, 0x0f, 0xff, 0xff, 0xf0, 0x7f, 0x3f, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xf8, 0x07,
0xff, 0x00, 0x7f, 0x0f, 0xff, 0xff, 0xf0, 0x7e, 0x3f, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xe0, 0x0f,
0xff, 0x80, 0x3f, 0x0f, 0xff, 0xff, 0xf0, 0x7e, 0x3f, 0xff, 0xff, 0xf0, 0x1e, 0x0f, 0xc0, 0x1f,
0xff, 0xc0, 0x3f, 0x0f, 0xff, 0xff, 0xf0, 0x7e, 0x3f, 0xff, 0xff, 0xf0, 0x00, 0x0f, 0xc0, 0x3f,
0xff, 0xc0, 0x3f, 0x0f, 0xff, 0xff, 0xf0, 0x7e, 0x7f, 0xff, 0xff, 0xf0, 0x00, 0x0f, 0xc0, 0x3f,
0xff, 0xe0, 0x1f, 0x0f, 0xff, 0xff, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x0f, 0xc0, 0x7f,
0xff, 0xe0, 0x1f, 0x0f, 0xff, 0xff, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0f, 0xc0, 0x7f,
0xff, 0xe0, 0x3f, 0x0f, 0xff, 0xff, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xc0, 0x7f,
0xff, 0xc0, 0x3f, 0x0f, 0xff, 0xff, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xc0, 0x7f,
0xff, 0xc0, 0x3f, 0x0f, 0xff, 0xc3, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xf7, 0xff, 0x0f, 0xc0, 0x7f,
0xff, 0xc0, 0x3f, 0x0f, 0xfc, 0x03, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xf3, 0xff, 0x0f, 0xc0, 0x7f,
0xff, 0xc0, 0x3f, 0x0f, 0xf0, 0x03, 0xf0, 0x7f, 0x7f, 0xff, 0xff, 0xf1, 0xff, 0x0f, 0xc0, 0x3f,
0xff, 0xc0, 0x3f, 0x0f, 0xe0, 0x03, 0xf0, 0x7f, 0x3f, 0xff, 0xff, 0xf3, 0xff, 0x0f, 0xc0, 0x3f,
0xff, 0x00, 0x3f, 0x0f, 0xe0, 0x03, 0xf8, 0xff, 0x3f, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xc0, 0x1f,
0xfe, 0x00, 0x7f, 0x0f, 0xf0, 0x03, 0xfc, 0xff, 0x3f, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xe0, 0x0f,
0xfe, 0x01, 0xff, 0x0f, 0xf0, 0x03, 0xff, 0xff, 0x3f, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xf8, 0x0f,
0xfc, 0x03, 0xff, 0x0f, 0xf0, 0x03, 0xff, 0xff, 0x1f, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xfc, 0x07,
0xfc, 0x03, 0xff, 0x07, 0xe0, 0x01, 0xff, 0xfc, 0x07, 0xff, 0xff, 0xff, 0xff, 0x0f, 0xfc, 0x07,
0xfe, 0x01, 0xff, 0x00, 0x00, 0x00, 0x3f, 0xe0, 0x00, 0x7e, 0x00, 0x0f, 0x80, 0x0f, 0xf8, 0x07,
0xfe, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xe0, 0x07,
0xff, 0x00, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x0f,
0xff, 0xf0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x7f,
0xff, 0xfc, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x81, 0xff,
0xff, 0xfe, 0x00, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff,
0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xff,
0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0xff,
0xff, 0xff, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0xff,
static const uint8_t  PROGMEM image[] = {
// 'pubg 1 (1)', 128x64px
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xc0, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0xf0, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xfc, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0xfe, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xff, 0xfe, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x7f, 0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xfe, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x7f, 0x81, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x78, 0xc0, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x07, 0xfc, 0xe3, 0x3f, 0xe0, 0x40, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x0f, 0xfe, 0x66, 0x7f, 0xe0, 0x78, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x0f, 0xff, 0x81, 0xff, 0xf0, 0x7c, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x1f, 0xff, 0xc7, 0xff, 0xf0, 0x7c, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x1f, 0xff, 0xc7, 0xff, 0xf0, 0x3e, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x1f, 0xff, 0xc7, 0xff, 0xf0, 0x3e, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x3f, 0xff, 0x87, 0xff, 0xf0, 0x3e, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x7f, 0xff, 0x87, 0xff, 0xf0, 0x3e, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xf8, 0x7f, 0xff, 0x07, 0xff, 0xf0, 0x3e, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xfe, 0x7f, 0xff, 0x07, 0xff, 0xf0, 0x3f, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0x3f, 0xff, 0x07, 0xff, 0xf0, 0x7f, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x9f, 0xfe, 0x0f, 0xff, 0xf1, 0xff, 0xc0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0x9f, 0xfe, 0x07, 0xff, 0xf3, 0xff, 0xe0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1f, 0xff, 0x07, 0xfe, 0x07, 0xff, 0xc3, 0xff, 0xf0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1f, 0xff, 0x03, 0xfe, 0x03, 0xff, 0x81, 0xff, 0xf0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe, 0x03, 0xfe, 0x03, 0xff, 0xc0, 0xff, 0xe0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1f, 0xf8, 0x07, 0xfe, 0x03, 0xff, 0xe0, 0x1f, 0xe0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3f, 0xc0, 0x07, 0xfe, 0x05, 0xff, 0xe0, 0x0f, 0xf0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3f, 0x80, 0x0f, 0xfe, 0x07, 0xff, 0xe0, 0x07, 0xf0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x0f, 0xfe, 0x07, 0xff, 0xe0, 0x03, 0xf0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x7c, 0x01, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x01, 0xf0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xfc, 0x03, 0x80, 0x00, 0x00, 0x00, 0x07, 0x01, 0xf8, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xfc, 0x03, 0x80, 0x00, 0x00, 0x00, 0x07, 0x01, 0xf8, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xf8, 0x0f, 0x9f, 0xdd, 0xcf, 0xff, 0xe7, 0xc1, 0xfc, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xf0, 0x03, 0x9d, 0xdd, 0xce, 0xfe, 0xe7, 0x00, 0xfc, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0xf0, 0x03, 0x9d, 0xdd, 0xce, 0xde, 0x07, 0x01, 0xfc, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0f, 0xf8, 0x03, 0x9f, 0xdd, 0xdf, 0xdd, 0xe7, 0x03, 0xfe, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0f, 0xf8, 0x03, 0x9f, 0x9d, 0xce, 0xdc, 0xe7, 0x00, 0xfe, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0xe0, 0x03, 0x9c, 0x1d, 0xce, 0xfc, 0xe7, 0x00, 0xfc, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0f, 0x80, 0x07, 0x9c, 0x1f, 0xcf, 0xff, 0xe7, 0xc0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x1e, 0x00, 0x07, 0x9c, 0x1f, 0xc7, 0xcf, 0xe7, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x3c, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x78, 0x00, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00,
static const uint8_t  PROGMEM image_data[] = {
// 'download (9) (1)', 128x64px
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xfc, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xf8, 0x01, 0x00, 0x8a, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x0f, 0xf0, 0x00, 0xc4, 0x03, 0xff, 0x80, 0xf0, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x01, 0x00, 0x00, 0x24, 0x0a, 0xff, 0xff, 0xff, 0x80, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x3c, 0x0f, 0xff, 0xff, 0x7f, 0xf0, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xf8, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x04, 0x0f, 0xff, 0xff, 0xff, 0xff, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3f, 0x80, 0x00, 0x00, 0x00, 0x05, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
0x00, 0x00, 0x00, 0x00, 0xff, 0x80, 0x00, 0x04, 0x00, 0x35, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
0x00, 0x00, 0x00, 0x07, 0xff, 0x80, 0x00, 0x00, 0x00, 0x0e, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
0x00, 0x00, 0x00, 0x1f, 0x3f, 0xe0, 0x00, 0x00, 0x01, 0xdf, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
0x00, 0x00, 0x00, 0x3f, 0xff, 0x40, 0x00, 0x00, 0x0f, 0x7c, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
0x1f, 0x07, 0xff, 0x3f, 0xff, 0xf0, 0x00, 0x00, 0x07, 0xbc, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x60, 0x00, 0x03, 0xf8, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x00, 0x07, 0xfc, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0f, 0xe8, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe7, 0x00, 0x0c, 0x7d, 0xcf, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x03, 0x00, 0x0c, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0f, 0xc6, 0x19, 0xff, 0xdf, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x3f, 0xe1, 0xf3, 0xff, 0xe7, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf9, 0xe7, 0xff, 0xfd, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xf7, 0xff, 0xfe, 0x1f, 0xff, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xf7, 0xff, 0xff, 0x1f, 0xff, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xcf, 0xff, 0xff, 0x3f, 0xff, 0xfc, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xcf, 0xff, 0xff, 0x3f, 0xff, 0xfc, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc7, 0xff, 0xff, 0x1f, 0xff, 0xfc, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc7, 0xff, 0xfe, 0x1f, 0xff, 0xfe, 0x7f, 0x3f, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xe3, 0xff, 0xfe, 0x0f, 0xff, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xff, 0xff, 0x07, 0xff, 0xfc, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc3, 0xff, 0xff, 0x07, 0xff, 0xf8, 0x1f, 0xe7, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x83, 0xff, 0xff, 0x07, 0xff, 0xf0, 0x1f, 0xff, 0xff, 0xff, 0x9f,
0xff, 0xff, 0xff, 0xff, 0xff, 0x81, 0x7f, 0xff, 0x07, 0xff, 0xf8, 0x07, 0xff, 0xff, 0xff, 0xdf,
0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xff, 0xff, 0x03, 0xff, 0xf8, 0x00, 0x07, 0xff, 0xfe, 0x63,
0xff, 0xff, 0xfc, 0x07, 0xe2, 0x00, 0xff, 0xff, 0x03, 0xff, 0xc0, 0x01, 0xff, 0xff, 0xe0, 0x07,
0xff, 0xff, 0xc0, 0x07, 0xf8, 0x00, 0xff, 0xff, 0x03, 0xff, 0x08, 0x07, 0xff, 0xff, 0xe0, 0x00,
0xfe, 0x70, 0x60, 0x0f, 0xfc, 0x08, 0xff, 0xff, 0x03, 0xfd, 0xf0, 0x01, 0xff, 0xff, 0x70, 0x00,
0xfe, 0x00, 0x00, 0x1d, 0xf8, 0x1d, 0xff, 0xff, 0x01, 0xff, 0x80, 0x00, 0xbf, 0xff, 0xf8, 0x00,
0x03, 0x70, 0x00, 0xff, 0xc6, 0x7f, 0xff, 0xff, 0x81, 0xff, 0xf0, 0x7c, 0x3f, 0xff, 0xff, 0x80,
0x00, 0x30, 0x07, 0xff, 0xf0, 0x7f, 0xff, 0xff, 0x81, 0xff, 0xf0, 0xfc, 0xff, 0xff, 0xff, 0xe0,
0x01, 0xcf, 0x07, 0xf8, 0xb0, 0x7f, 0xff, 0xff, 0x80, 0xff, 0xf0, 0x20, 0x80, 0xff, 0xff, 0xe0,
0x00, 0x00, 0x00, 0x7c, 0x01, 0xff, 0xff, 0xff, 0x80, 0xff, 0xf0, 0x03, 0x01, 0xff, 0xff, 0x60,
0x00, 0x00, 0x00, 0x7e, 0x07, 0xcf, 0xff, 0xff, 0x80, 0xff, 0xf0, 0x03, 0x03, 0xff, 0xff, 0x04,
0x00, 0x00, 0x00, 0x78, 0x00, 0x60, 0xff, 0xff, 0xc0, 0xff, 0xf8, 0x00, 0x20, 0xff, 0xff, 0xc4,
0x00, 0x00, 0x03, 0xf0, 0x00, 0x20, 0x00, 0x7f, 0xe0, 0xff, 0xf0, 0x00, 0xf8, 0x3f, 0x83, 0xe0,
0x00, 0x00, 0x07, 0xe0, 0x01, 0xf0, 0x00, 0x00, 0xf0, 0xf8, 0x00, 0x00, 0x9c, 0x3e, 0x00, 0x00,
0x00, 0x00, 0x01, 0x80, 0x37, 0xdf, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x18, 0x7f, 0x0c, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x3f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x0c, 0x06, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x00,
0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff,
0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xff,
0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x1e,
0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00,
static const uint8_t  PROGMEM image1[] =
{// 'pubg mobile (1)', 128x64px
0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xc3, 0xf8, 0xc6, 0x3f, 0x8f, 0xc3, 0xf0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xc3, 0xf8, 0xe7, 0x3f, 0x9f, 0xe3, 0xf0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xc3, 0xf8, 0xe7, 0x3f, 0x9f, 0xe3, 0xe0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc3, 0xb8, 0xe7, 0x3b, 0x9c, 0xe3, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc3, 0xb8, 0xe7, 0x3b, 0x9c, 0x43, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc3, 0xb8, 0xe7, 0x3b, 0x9c, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc3, 0xb9, 0xe7, 0x3b, 0x9c, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc3, 0xb8, 0xe7, 0x7f, 0x9c, 0xe3, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc7, 0xf8, 0xe7, 0x7f, 0x9d, 0xe3, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc7, 0xf9, 0xe7, 0x7f, 0x9c, 0xe3, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc7, 0xf9, 0xe7, 0x3b, 0x9c, 0xe3, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc3, 0x80, 0xe7, 0x3b, 0x9c, 0xe3, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xc3, 0x81, 0xe7, 0x3b, 0x9c, 0xe3, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xc3, 0x81, 0xff, 0x3f, 0x9f, 0xe3, 0xe0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xc3, 0x80, 0xff, 0x3f, 0x9f, 0xe3, 0xf0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xc3, 0x00, 0xfe, 0x3f, 0x0f, 0xc3, 0xf0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x11, 0xe3, 0xc6, 0x61, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x33, 0xf3, 0xe6, 0x63, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xf3, 0x33, 0xe6, 0x63, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xf3, 0x37, 0xe6, 0x63, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xf3, 0x33, 0x66, 0x63, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xb3, 0xf3, 0xe6, 0x73, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00,
static const uint8_t  PROGMEM image3[] =
{// 'images (3)', 128x64px
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x0f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x10, 0x00, 0x00, 0x1f, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x38, 0x00, 0x00, 0x3f, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0xfe, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0xee, 0x01, 0x80, 0xff, 0xff, 0xff, 0xff, 0x80, 0xc0, 0x67, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x01, 0xb8, 0xff, 0xff, 0xff, 0xff, 0x8e, 0x80, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x01, 0xc8, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x0f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xf8, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x19, 0xf8, 0x00, 0x00, 0x00, 0x80, 0x0f, 0xe8, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x07, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xf0, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x0f, 0x00, 0x1c, 0xff, 0xf8, 0x0f, 0xff, 0x1c, 0x20, 0x78, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0xc7, 0x00, 0x06, 0x7f, 0xff, 0xff, 0xff, 0x30, 0x00, 0xe1, 0x80, 0x00, 0x01,
0x80, 0x00, 0x08, 0x02, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x20, 0x08, 0x00, 0x01,
0x80, 0x01, 0x80, 0x1c, 0x00, 0x07, 0x80, 0x00, 0x00, 0x00, 0xf0, 0x00, 0x3c, 0x00, 0x80, 0x01,
0x80, 0x1c, 0x01, 0xe0, 0x00, 0x07, 0xc0, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x03, 0xc0, 0x1c, 0x01,
0x80, 0x38, 0x0e, 0x00, 0x03, 0x0f, 0xc0, 0x00, 0x00, 0x01, 0xf8, 0x40, 0x00, 0x38, 0x0e, 0x01,
0x80, 0x08, 0x18, 0x00, 0x00, 0x4f, 0xcc, 0x01, 0x20, 0x30, 0xf9, 0x00, 0x00, 0x0c, 0x08, 0x01,
0x80, 0x03, 0xf0, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x03, 0xc0, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x01,
0x80, 0x01, 0xc0, 0x00, 0x00, 0x03, 0xc0, 0x3c, 0x1e, 0x01, 0xc0, 0x00, 0x00, 0x01, 0xc0, 0x01,
0x80, 0x00, 0x20, 0x00, 0x00, 0x00, 0x78, 0x07, 0xf0, 0x0f, 0x00, 0x00, 0x00, 0x02, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x01, 0x80, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xe0, 0x07, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7e, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
 static const uint8_t  PROGMEM image2[] =
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x80, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x33, 0xc0, 0x0f, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x3b, 0x87, 0x8f, 0x70, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xf0, 0x79, 0x03, 0x02, 0xf0, 0x7e, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0xf0, 0x7c, 0x00, 0x09, 0xf8, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xf8, 0xff, 0xe0, 0x3f, 0xf8, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xf8, 0xff, 0xf0, 0x3f, 0xf8, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xf8, 0xff, 0xf0, 0x3f, 0xf8, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xfc, 0x7f, 0xe0, 0x3f, 0xf8, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xfc, 0x7f, 0xe0, 0x1f, 0xf8, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xf8, 0x7f, 0xe0, 0x1f, 0xf8, 0x7f, 0xc0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0x7f, 0xc0, 0x1f, 0xf0, 0x7f, 0xc0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xf8, 0x7f, 0xc0, 0x1f, 0xf8, 0x7f, 0xc0, 0x00, 0x00, 0x00, 0x00,
static const uint8_t  PROGMEM image4[] =
  {// 'images (3) (1)', 128x64px
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x0f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0x03, 0xff, 0x83, 0xb4, 0x7a, 0xfc, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0x0f, 0xff, 0x02, 0x84, 0x58, 0x10, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x3f, 0xff, 0x03, 0xa4, 0x79, 0xd0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xff, 0xe7, 0xff, 0x83, 0x7c, 0x4a, 0x74, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xc1, 0xff, 0x82, 0x4c, 0x4b, 0x94, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x81, 0xff, 0xc2, 0x36, 0x46, 0x58, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xe1, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0xc0, 0xff, 0xf3, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x80, 0x7f, 0xf2, 0x02, 0x08, 0x0c, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x80, 0x7f, 0xf2, 0x02, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x00, 0x3f, 0xf2, 0x42, 0x1a, 0x0c, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x01, 0x3f, 0xe3, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xfe, 0x41, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xfe, 0xc0, 0x9f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3f, 0xfc, 0x80, 0xdf, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3f, 0xf8, 0x80, 0x4f, 0xfe, 0x00, 0x07, 0xfe, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1f, 0xfd, 0x80, 0x7f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0f, 0xff, 0x80, 0x7f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
 static const uint8_t  PROGMEM image5[] =
    // 'images (4) (1)', 128x64px
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x18, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x04, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x01, 0xc0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x01, 0x80, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x01, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x08, 0x24, 0xfb, 0x80, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xc7, 0xff, 0x3e, 0x3c, 0xff, 0xe3, 0xff, 0x07, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x8f, 0xff, 0xbe, 0x3c, 0xff, 0xe7, 0xaf, 0x00, 0x07, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0x00, 0x07, 0xcf, 0xbe, 0x3c, 0xf1, 0xe7, 0x8f, 0x01, 0x81, 0xff, 0xff, 0xff,
0xff, 0xff, 0xfe, 0x00, 0x07, 0xc7, 0xbe, 0x3e, 0xf1, 0xe7, 0x8f, 0x3f, 0xc0, 0xff, 0xff, 0xff,
0xff, 0xff, 0xfc, 0x3f, 0x17, 0xc7, 0xfe, 0x3e, 0xff, 0xe7, 0x00, 0x80, 0xc0, 0x71, 0xff, 0xff,
0xff, 0xff, 0xfc, 0x30, 0x03, 0xc7, 0xfe, 0x3e, 0xff, 0xc7, 0x3e, 0x07, 0x40, 0x00, 0x1f, 0xff,
0xff, 0xff, 0xfc, 0x37, 0x83, 0xff, 0xfe, 0x3e, 0xf3, 0xe7, 0x3f, 0x03, 0x40, 0x0e, 0x0f, 0xff,
0xff, 0xc0, 0x78, 0x24, 0x03, 0xff, 0xbe, 0x3e, 0xf1, 0xe7, 0x0e, 0x01, 0x07, 0x78, 0x0f, 0xff,
0xfe, 0x08, 0x08, 0x24, 0x03, 0xe0, 0x3e, 0x3e, 0xf1, 0xe7, 0x0f, 0x00, 0x07, 0xc0, 0x9f, 0xff,
0xfc, 0x1f, 0x80, 0x24, 0x03, 0xe0, 0x3f, 0x3e, 0xf1, 0xe7, 0x0e, 0x00, 0x1f, 0x01, 0x1f, 0xff,
0xfc, 0x07, 0xf0, 0x00, 0x03, 0xe0, 0x1f, 0xfe, 0xff, 0xef, 0xfe, 0x00, 0xfe, 0x00, 0x3f, 0xff,
0xfe, 0x01, 0xff, 0x00, 0x03, 0xe0, 0x1f, 0xfe, 0xff, 0xc7, 0xfe, 0x1f, 0xec, 0x00, 0xff, 0xff,
0xff, 0xc0, 0x0f, 0xe0, 0x0f, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfe, 0x00, 0x03, 0xff, 0xff,
0xff, 0xf0, 0x01, 0xfe, 0x7f, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x0f, 0xf0, 0x00, 0x0f, 0xff, 0xff,
0xff, 0xfe, 0x00, 0x1f, 0xff, 0xfc, 0x00, 0x3f, 0xe0, 0x00, 0x7f, 0x80, 0x00, 0xff, 0xff, 0xff,
0xff, 0xff, 0xf0, 0x01, 0xff, 0xff, 0xc0, 0xff, 0xfe, 0x03, 0xff, 0x00, 0x00, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0x00, 0x7f, 0xff, 0xf3, 0xff, 0xff, 0x9f, 0xfe, 0x00, 0x01, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0x80, 0x1f, 0xff, 0xf3, 0xff, 0xff, 0xcf, 0xf8, 0x00, 0x01, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xc0, 0x03, 0xff, 0xe7, 0xff, 0xff, 0xef, 0xf8, 0x00, 0x01, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xe0, 0x00, 0x7f, 0xef, 0xff, 0xff, 0xef, 0xc0, 0x00, 0x01, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf0, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xde, 0x00, 0x00, 0x01, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf0, 0x00, 0x01, 0xff, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf0, 0x00, 0x00, 0x17, 0xff, 0xe0, 0xc0, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x07, 0x1f, 0xf1, 0xc4, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf0, 0x00, 0x00, 0x47, 0xff, 0xff, 0x9f, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf0, 0x00, 0x01, 0xfb, 0xff, 0xff, 0xbf, 0xf0, 0x00, 0x03, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf0, 0x00, 0x0f, 0xf8, 0x7f, 0xfc, 0x0f, 0xff, 0x00, 0x01, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf0, 0x00, 0x7f, 0xfe, 0x7f, 0xff, 0xff, 0xff, 0x80, 0x01, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xe0, 0x00, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x7f, 0x80, 0x00, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xe0, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xfe, 0x7f, 0xc0, 0x00, 0x7f, 0xff, 0xff,
0xff, 0xff, 0xff, 0xc0, 0x00, 0x7f, 0xff, 0xc8, 0x07, 0xfe, 0xff, 0xf0, 0x00, 0x7f, 0xff, 0xff,
0xff, 0xff, 0xff, 0x80, 0x01, 0xff, 0xff, 0xe0, 0x07, 0xfd, 0xff, 0xfe, 0x00, 0x1f, 0xff, 0xff,
0xff, 0xff, 0xff, 0x00, 0x0f, 0xff, 0xff, 0x00, 0x00, 0x73, 0xe1, 0xff, 0x80, 0x03, 0xff, 0xff,
0xff, 0xff, 0xfe, 0x00, 0x7f, 0x83, 0xf0, 0x00, 0x00, 0x0f, 0xc0, 0x7f, 0xfe, 0x00, 0x3f, 0xff,
0xff, 0xff, 0xf0, 0x01, 0xfe, 0x03, 0xfc, 0x00, 0x00, 0x0f, 0x80, 0x0f, 0xff, 0xe0, 0x07, 0xff,
0xff, 0xff, 0xc0, 0x3f, 0xf8, 0x01, 0xfe, 0x00, 0x00, 0x1f, 0x80, 0x87, 0xff, 0xff, 0x00, 0xff,
0xff, 0xfe, 0x01, 0xff, 0xe0, 0x01, 0xf8, 0x00, 0x00, 0x3f, 0x04, 0x01, 0xff, 0xff, 0xc0, 0x3f,
0xff, 0xe0, 0x0f, 0xff, 0x81, 0x00, 0x80, 0x00, 0x08, 0x00, 0x30, 0x00, 0x7f, 0xff, 0xf8, 0x1f,
0xff, 0x00, 0xff, 0xfe, 0x00, 0x30, 0x00, 0x00, 0xc0, 0x01, 0x80, 0x00, 0x1f, 0xff, 0xf0, 0x1f,
0xfc, 0x03, 0xff, 0xf0, 0x00, 0x0e, 0x80, 0x00, 0x0c, 0x1c, 0x00, 0x00, 0x07, 0xff, 0xe0, 0x3f,
0xf8, 0x1f, 0xff, 0xe0, 0x00, 0x01, 0x00, 0x18, 0x00, 0x00, 0x00, 0x1e, 0x00, 0xff, 0xc0, 0x3f,
0xf8, 0x1f, 0xff, 0x00, 0x04, 0x00, 0x1c, 0x01, 0x06, 0x00, 0x00, 0xff, 0x80, 0x3f, 0x80, 0x7f,
0xf8, 0x0f, 0xfc, 0x00, 0x3f, 0xc0, 0x03, 0x60, 0x30, 0x00, 0x03, 0xff, 0xe0, 0x0f, 0x00, 0xff,
0xfc, 0x07, 0xf0, 0x00, 0xff, 0xf8, 0x00, 0x87, 0x80, 0x00, 0x0f, 0xff, 0xf8, 0x00, 0x01, 0xff,
0xfe, 0x01, 0xc0, 0x03, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xfc, 0x00, 0x03, 0xff,
0xff, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0x80, 0x0f, 0xff,
0xff, 0xc0, 0x00, 0x3f, 0xff, 0xff, 0xfe, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x1f, 0xff,
0xff, 0xf8, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
  static const uint8_t  PROGMEM image6[] =
    // 'images (5) (1)', 128x64px
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x8f, 0xff, 0xef, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xdf, 0xff, 0xff, 0x79, 0xfe, 0x0e, 0x74, 0xe2, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x1a, 0xc0, 0x1f, 0xb8, 0xdc, 0x7f, 0x7f, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xbf, 0xff, 0xff, 0x9f, 0x0f, 0xe1, 0xe8, 0xff, 0x3f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xbd, 0xff, 0x7f, 0x60, 0x7f, 0xf8, 0xb9, 0x7f, 0xff, 0xbf, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0x70, 0xff, 0xfd, 0xc0, 0xe7, 0xfc, 0x09, 0xdf, 0xfc, 0x1b, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0x70, 0xff, 0xf9, 0x00, 0x01, 0xe2, 0x01, 0xe7, 0xff, 0x13, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xd0, 0x3f, 0x60, 0x06, 0xf8, 0x30, 0x00, 0x02, 0xc3, 0x9f, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0x50, 0x30, 0x80, 0x3d, 0xff, 0x3d, 0x00, 0x06, 0x00, 0x6f, 0xff, 0xff, 0xff,
0xff, 0xff, 0xfb, 0xa2, 0x00, 0x00, 0x00, 0x02, 0x17, 0x00, 0x0f, 0x00, 0x3f, 0xff, 0xff, 0xff,
0xff, 0xff, 0xdb, 0x82, 0x04, 0x00, 0x0f, 0x90, 0x37, 0x00, 0x1f, 0x00, 0x07, 0xff, 0xff, 0xff,
0xff, 0xff, 0x70, 0x00, 0x00, 0x00, 0x0b, 0xf7, 0xe6, 0x00, 0x00, 0x00, 0x20, 0xff, 0xff, 0xff,
0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x71, 0x7f, 0xff, 0xff,
0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7e, 0x10, 0x00, 0x00, 0x08, 0x13, 0xff, 0xff, 0xff,
0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x06, 0x72, 0x76, 0x00, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff,
0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x1c, 0x00, 0xbe, 0x08, 0x00, 0x00, 0x00, 0x1f, 0xff, 0xff,
0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x70, 0x45, 0x02, 0x4c, 0x00, 0x00, 0x00, 0x1f, 0xff, 0xff,
0xff, 0xfc, 0x30, 0x00, 0x00, 0x00, 0xe7, 0xe2, 0x84, 0x26, 0x00, 0x00, 0x00, 0x3b, 0x7f, 0xff,
0xff, 0xfe, 0x1b, 0x00, 0x00, 0x04, 0xef, 0x30, 0x1a, 0xe6, 0x40, 0x00, 0x00, 0x67, 0xfe, 0xff,
0xff, 0xff, 0x19, 0xf0, 0x00, 0x09, 0xc8, 0x08, 0x6f, 0x67, 0x60, 0x00, 0x00, 0x07, 0xbf, 0xff,
0xff, 0xff, 0xd9, 0xfc, 0x00, 0x19, 0xdf, 0x0c, 0x7f, 0xe7, 0x20, 0x00, 0x00, 0x00, 0x01, 0xff,
0xff, 0xff, 0xf9, 0xff, 0x00, 0x19, 0xd0, 0x38, 0x76, 0x07, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff,
0xff, 0xff, 0xf1, 0xff, 0x00, 0x1d, 0x9f, 0xf0, 0x71, 0xc7, 0x20, 0x00, 0x00, 0x00, 0x06, 0xff,
0xff, 0xff, 0xfb, 0x00, 0x00, 0x19, 0xbf, 0xd8, 0x7f, 0x67, 0x20, 0x00, 0x00, 0x00, 0x0d, 0xff,
0xff, 0xff, 0xec, 0x00, 0x78, 0x0d, 0xbf, 0xf0, 0x7f, 0xe6, 0x40, 0x00, 0x44, 0x22, 0x1e, 0xff,
0xff, 0xff, 0xf8, 0x00, 0x0c, 0x1c, 0x1f, 0xf0, 0x5f, 0xe6, 0x10, 0x07, 0xff, 0xff, 0xff, 0xff,
0xff, 0xe1, 0xe8, 0x00, 0x04, 0x37, 0x1f, 0xe0, 0x7f, 0xe4, 0xf0, 0x00, 0xff, 0xff, 0xff, 0xff,
0xfe, 0x13, 0xa0, 0x00, 0x00, 0x3f, 0x8f, 0xe0, 0x3f, 0xe0, 0x48, 0x0f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xfe, 0xfc, 0x00, 0x00, 0xc7, 0x07, 0xe0, 0x7f, 0x82, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xfc, 0x00, 0x00, 0xfa, 0x13, 0xe0, 0x40, 0x80, 0x7e, 0x41, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xfe, 0x20, 0x02, 0x3c, 0x12, 0xe0, 0x2e, 0x01, 0xc3, 0x81, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xfe, 0x00, 0x01, 0x80, 0xa4, 0xe0, 0x3f, 0x48, 0x1e, 0xc1, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xfd, 0xf8, 0x01, 0xe5, 0xe7, 0x20, 0x2f, 0x27, 0x9e, 0xf1, 0xe7, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf8, 0x01, 0xc0, 0x2e, 0xc0, 0x7f, 0x0f, 0xce, 0xf3, 0xa3, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf8, 0x02, 0x00, 0x0f, 0xe0, 0x7f, 0x6d, 0xee, 0xff, 0xf7, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x83, 0x00, 0x00, 0x20, 0x3f, 0xf3, 0xee, 0x7c, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xc1, 0x00, 0x00, 0x00, 0x3f, 0x3b, 0x61, 0x3e, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xe8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x3f, 0x67, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xce, 0x80, 0x00, 0x00, 0x00, 0x00, 0x77, 0xbf, 0xef, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xbe, 0x41, 0x03, 0x30, 0x06, 0x0c, 0x07, 0x9f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xa0, 0x40, 0x01, 0x00, 0x04, 0x0c, 0x00, 0x9f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x80, 0x60, 0x01, 0x00, 0x04, 0x44, 0x60, 0x1f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xc3, 0xe0, 0x00, 0x00, 0x04, 0x0c, 0x70, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x04, 0x04, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xa1, 0x00, 0x02, 0x04, 0x04, 0x6f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xe1, 0x0e, 0x00, 0x04, 0x40, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0a, 0x00, 0x04, 0x00, 0x17, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc1, 0x8f, 0x00, 0x00, 0x00, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xb0, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xbf, 0xff, 0xff, 0xff, 0xff, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_GS2 104
#define NOTE_A2  110
#define NOTE_AS2 117
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_CS3 139
#define NOTE_D3  147
#define NOTE_DS3 156
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_FS3 185
#define NOTE_G3  196
#define NOTE_GS3 208
#define NOTE_A3  220
#define NOTE_AS3 233
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_CS4 277
#define NOTE_D4  294
#define NOTE_DS4 311
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_FS4 370
#define NOTE_G4  392
#define NOTE_GS4 415
#define NOTE_A4  440
#define NOTE_AS4 466
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_CS5 554
#define NOTE_D5  587
#define NOTE_DS5 622
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_FS5 740
#define NOTE_G5  784
#define NOTE_GS5 831
#define NOTE_A5  880
#define NOTE_AS5 932
#define NOTE_B5  988
#define NOTE_C6  1047
#define NOTE_CS6 1109
#define NOTE_D6  1175
#define NOTE_DS6 1245
#define NOTE_E6  1319
#define NOTE_F6  1397
#define NOTE_FS6 1480
#define NOTE_G6  1568
#define NOTE_GS6 1661
#define NOTE_A6  1760
#define NOTE_AS6 1865
#define NOTE_B6  1976
#define NOTE_C7  2093
#define NOTE_CS7 2217
#define NOTE_D7  2349
#define NOTE_DS7 2489
#define NOTE_E7  2637
#define NOTE_F7  2794
#define NOTE_FS7 2960
#define NOTE_G7  3136
#define NOTE_GS7 3322
#define NOTE_A7  3520
#define NOTE_AS7 3729
#define NOTE_B7  3951
#define NOTE_C8  4186
#define NOTE_CS8 4435
#define NOTE_D8  4699
#define NOTE_DS8 4978
int melody[] = {
  NOTE_A4, NOTE_A4, NOTE_E6,NOTE_E6, NOTE_F6, NOTE_F6, NOTE_G6,NOTE_G6,
  NOTE_G5, NOTE_A5, NOTE_A5,NOTE_E6, NOTE_D6, NOTE_C6, NOTE_B5,NOTE_C6,
  NOTE_A5, NOTE_C6, NOTE_B5,NOTE_C6, NOTE_B5, NOTE_A5, NOTE_A5,NOTE_E6,
  NOTE_D6, NOTE_C6, NOTE_B5,NOTE_C6, NOTE_A5, NOTE_C6, NOTE_B5,NOTE_C6,
  NOTE_B5, NOTE_A5, NOTE_A5,NOTE_A6, NOTE_G6, NOTE_D6, NOTE_E6
int noteDurations[] = {
  8,8,8,8,8,8,8,8,
  8,8,8,8,8,8,8,8,
  8,8,8,8,8,8,8,8,
  8,8,8,8,8,8,8,8,
  2,1,4,4,1,6,6,1,
  6,6,1,6,6,1,6,6,
  1,6,6,1,6,6,1,6,
  6,1,6,4,2,2,1
void setup() {
    Serial.begin(115200);
  if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    for(;;);
void loop()
  delay(2000);
  for (int thisNote = 0; thisNote < 63; thisNote++)
    int noteDuration = 800 / noteDurations[thisNote];
    tone(6, melody[thisNote], noteDuration);
    int pauseBetweenNotes = noteDuration +60;
    delay(pauseBetweenNotes);
    noTone(2);
    if (millis()<3500)
      draw1();
    else if(millis()>3500 && millis()<7000)
      draw2();
    else if(millis()>7000 && millis()<10500)
      draw3();
    else if(millis()>10500 && millis()<14000)
      draw4();
     else if(millis()>14000 && millis()<17500)
      draw5();
     else if(millis()>17500 && millis()<21000)
      draw6();
     else if(millis()>21000 && millis()<25000)
      draw7();
     else if(millis()>25000 && millis()<29000)
      draw8();
      else if(millis()>29000 && millis()<33000)
      draw9();
  void draw1(){
    display.clearDisplay();
  // Draw bitmap on the screen
  display.drawBitmap(0, 0, image_data_20190410_114707, 128, 64, 1);
  display.display();
  void draw2(){
     // Clear the buffer.
  display.drawBitmap(0, 0, image_data, 128, 64, 1);
  display.display();
   void draw3(){
  display.drawBitmap(0, 0, image, 128, 64, 1);
  display.display();
  void draw4(){
  display.drawBitmap(0, 0, image1, 128, 64, 1);
  display.display();
  void draw5(){
  display.drawBitmap(0, 0, image2, 128, 64, 1);
  display.display();
void draw6(){
  display.drawBitmap(0, 0, image3, 128, 64, 1);
  display.display();
  void draw7(){
  display.drawBitmap(0, 0, image4, 128, 64, 1);
  display.display();
  void draw8(){
  display.drawBitmap(0, 0, image5, 128, 64, 1);
  display.display();
  void draw9(){
  display.drawBitmap(0, 0, image6, 128, 64, 1);
  display.display();
