Introduction: PVC Canopy on Door/window
Hello friends !! Happy to post my first Instructable .
In this Instructable , I will show you how to build a quick and easy PVC Canopy .
You will need the following :-
* PVC pipes
* pvc Elbow
* pvc T-joint
* pvc shoe
* acrylic sheet
* screws
Tools:-
* screw driver
* hammer
* measuring tape
* pvc cutting saw
* drill machine
* PVC pipes
* pvc Elbow
* pvc T-joint
* pvc shoe
* acrylic sheet
* screws
Tools:-
* screw driver
* hammer
* measuring tape
* pvc cutting saw
* drill machine
Step 1: Materials and Tools
Collect the materials and tools to start the instructable
Step 2: Cutting the Material to Size
cutting pvc pipe
48inch × 3
21inch × 2
18inch × 2
11inch × 4
8 inch × 2
Acryilc sheet 58 × 30 inches
48inch × 3
21inch × 2
18inch × 2
11inch × 4
8 inch × 2
Step 3: Preparing the Upper Frame
make the frame with T joint elbow and shoe
use T joint for 22" pvc pipe from both side ,
attach a 8" pvc pipe to one end of T joint and a
2"pvc joint on other end to fix the elbow joint.
we have made the upper frame of the canopy
Step 4: Preparing the Lower and Back Frame
Now attach the 18" pvc pipe to te upper frame towards the shoe joint .
And elbow joint to other end.
take two 11" pvc pipes and join the T joint both on either side.
now your 11" one end will be fixed to the back frame of 18" pvc pipe at the elbow joint .
now extend with another 11" pipe to the T joint .
attach the shoe joint to this 11" pipe so that the upper frame gets fix to the lower frame..
now for middle support at the T joint take the 48" pipe and fix it ..
Step 5: Fix the Acrylic Sheet
screw the frame at all the joints so that it doesnt move
cut the acrylic sheet ..
i kept the sheet 5" outside from both ends
put rubber washer (orange)below the acrylic sheet so that it does not make noise when the wind blows
Yes .!! your canopy is ready
Step 6: Fix It to the Wall
drill holes and fix the canopy at the desired height ..
Thanks for veiwing my instructable .
