Introduction: PVC Dishtowel Holder
Ello guys
You know that moment when you have a lot of dishtowels hanging everywhere and when you need to pick up a hot teapot, you dont know where are they; just like in my case.
So i made a dishtowel holder, and all my towels are organized in one place and i dont need to run all over the kitchen to get one, lol. I hope you like.
Step 1: Tools and Parts
Okey,so for this pvc holder you'll need 2 m of 3/4 inch pvc pipe, little bit of fittings and some clamps. All these parts & tools you can find in your local hardware store and besides that, they aren't expensive; i mean it all cost me 3 dollars.
Parts :
- Pvc pipe (3/4 inch) 2 m
- Pvc knee 90* - 4 pcs
- Pvc tee-part - 3pcs
- Pvc clamps & screws - 2 pcs
Tools :
- Pvc pipe welder ( made my own from powerful soldering iron)
- Electric Jig-saw if you don't have pvc pipe cutter
- Measuring tape
- Pen or a marker
Step 2: Cutting & Assembling
First thing i did is i cut down 3 pcs of half of meter (0.5m) long pipes and afterwards i have cut down 4 pcs of 4cm pipe.
When thats all done, i've turned on pipe welder and while waiting it for to heat up; i sorted the elements how they should look, which you can see in pictures.
A moment where pipe welder reach its temperature you're ready to start welding and by that i welded longer parts of pipe with knees & shorter with Tee parts. Assembled it all and its kinda finished.
Step 3: Finishing & Mounting
The body of a dishtowel holder is ready and all that needs to be done is to mark where it should be placed. Job is almost done with 2 pvc clamps. But there is a problem with it, cause holder wont stay still. It starts do rotate because of the clamps; which are just for mounting,not for holding it stiff.
That problem can easily be solved with one last Tee part,welded in the middle of a longer part that is facing the wall. Its middle leg is going to prevent the whole body from rotating & with that adjustment dishtowel holder is finished.
If you've done it and it turned out just like it in the pictures,your awesome,congrats. :)
I really hope you like it and i would love to hear your comments and thoughts about it.
