Introduction: PVC Dog Bunk Bed
This elevated dog bed is great instead of flat dog beds
Your dogs will enjoy the elevated level
Step 1: Materials
1/2 inch PVC pipe (you can use 3/4 or a bigger pipe depending on the weight of your dog)
3/4 inch PVC
8 90 degree elbows
Saw
Clothe
Zip ties
3/4 inch PVC
8 90 degree elbows
Saw
Clothe
Zip ties
Step 2: Measuremennt
Measure the height, width, and length of your largest dog
Use the height for how tall the bed will be
Step 3: PVC Pipes
Cut the PVC pipes to the measurements of your dog
You need 4 x the three measurements
That is 8 pipes in total
Glue the pipes and angles with 4 angles at the top at each corner
Glue the same at the bottom
Do not glue the four pipes that hold the top frame
That is optional if you want it to be detachable
Step 4: Clothe
Make sure the frame is big enough for your dogs
Place fabric only on the 2nd level
Poke holes in the clothe and zip tie the fabric and pipe together
Step 5: Results
Put blankets and pillows on the levels to make your dogs comfortable
Don't forget to put the smaller dog on the top level
