Introduction: Upcycled Musical Instrument
Step 1: Step 1: Materials
- a PVC pipe that is 15 inches long and 1 inch in diameter
- a sheet of paper
- gorilla glue
- colored tape (optional)
- a drill
- a permanent marker
- scissors
Step 2: Step 2: Mark
You need to mark the hole in the pipe where you are going to drill
Step 3: Step 3: Get Ready to Drill
Get the drill and drill all of the holes , but make sure they don’t go through the back side of the pipe
Step 4: Step 4: Trace
After your all of your holes are drilled, placed the base of the pipe on the paper and trace around it
Step 5: Step 5: Glue
After you trace around the base, cut it out and glue it to the top of the pipe closest to the mouth hole
Step 6: Tape
After you glue the circle piece of paper to the top of the pipe, tape around it to secure and make sure no air can seep out
Step 7: Step 7: Decorate
Now that you have finished all of the logistics of your flute, you can decorate it with whatever you want; I personally used colored tape but its all up to you. When decorating MAKE SURE NOT TO COVER ANY HOLES !
