Introduction: PVC Hunting Longbow (Updated)
Want to make a $10 hunting bow?
That has 65 lbs draw? And a cheap way to hunt, But dont know what to use? Well you are in the right place!
Step 1: First You Will Need Some Paracord and Some PVC Pipe.
Ok so here is the parts you need
A one inch PVC pipe.
Paracord.
Sidecutters.
Drill and bit.
Duct tape (optional)
plastic Hanger (optional)
Paracord.
Sidecutters.
Drill and bit.
Step 2: Drill Two Holes.
Drill two holes on both ends of the pvc pipe.
Or with sidecutters you can cut it.
Dont complain like some dweebs and say it looks like there is another pipe in that one.
i experimented with it and cut and hammerd a 3/4 in pvc pipe in the ends 1 in pipe so the ends wont snap in serious tension. you can do the same if you want.
Step 3: Add the Paracord.
tie two loops in the ends of the paracord.
Using your foot, carefully bend the pvc pipe and put the paracord on the two ends.
You will need to adjust the string length until there is a good enough bend into it to pull back, let go, and not have it hit your hand.
Step 4: Tweeking
Dont stop now! The sky is the limit!
If you like things like this, i do it all on my youtube channel. Please subscribe to it!
Copy this link and paste it in your search bar:
https://www.youtube.com/watch?v=2F2eV6itIF4&feature=youtube_gdata_player
If you want you can add duct tape and a plastic hanger for a slit for the arrow to slide off.
and i added a metal sight.
Warning: this is no toy, and im not responsible if you hurt or kill someone. This can be used for hunting, so treat it like a gun and stay safe.
