Introduction: PVC Light/Lamp - Shade
In this Instructable, I demonstrate a way to make a PVC Lamp shade.
For this project, you will need a few PVC pipes, PVC pipe cutter and a hot glue gun.
You will also need an inflatable ball.
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1: Cut the PVC Pipe in Rings
I used a PVC pipe cutter to cut out rings.
I guess a table saw would have been a much faster option, but I had to use what I got.
The rings were cut approximately the same size, but not perfect.
Step 2: Glue the Rings Together (around the Ball)
I glued the first ring to the ball, so the lampshade would not move.
Then I glued rest of the rings to each other, but not to the ball.
Step 3: Take Out the Ball
When that was done, I deflated the ball to pull it out from the shade.
Then I just hung it on one of my ceiling lights.
