Introduction: PVC Pipe Letters G and H
Would you like to build any letters out of PVC Pipe? Now you can! Just with these little easy steps! Let me show you how you can build a G and a H!
Step 1: Parts
You'll need PVC Pipe, PVC connectors (90 degree elbow, 45 degree elbow, and a T), a ruler, a PVC cutter, and a pencil!
Step 2: First
Cut the PVC pipe into 6, 1.5 inch parts! And 5, 1.5 inch parts!
Step 3: FIrst Let's Make the G!
Connect the PVC pipes to the connectors! Connect the 90 degrees with the other 90.
Step 4: Next
Put the 45 degrees together making a U shape letter!
Step 5: Next Connecting the Whole Thing Together!
Connect the 45 degree PVC to the 90 degrees! And flatten the PVC out, so the parts are all on the same plain. Ta-da you've made the letter G!
Step 6: Now Onto the Letter H! First
Get the 5, 1.5 inch parts and two T connectors
Step 7: Next
Take one of the T connectors and put two PVC pipes into the bottom and top holes. Then do the same but add another pipe into the side of the T
Step 8: Finally!
Now connect them!! YAY! You've made a H!
Step 9: Done!
Now you can show off these letters to your friends! :)
