Introduction: PVC Pipe Nunchucks for Under $10
Everyone wants to be a ninja, and now you can with these awesome nunchucks! Thanks to TH3 R4ND0M H3R0 who was the co-creator in this project.
Step 1: The Junk You Need
The stuff you need for these chucks are
2 - 14" pieces of 1/2" PVC Pipe
4 - 1/2" PVC end caps
2 - 1/4" x 2" Eyebolts with nuts
1 - 6"-7" piece of chain
2 - 12" pieces of foam pipe insulation (optional)
Step 2: Drilling
Drill a hole in the middle of 2 end caps that the eyebolts can fit snugly into
Step 3: Let Your Chain Hang Low
Use your manly muscles and pry the eyebolt apart so you can fit the chain on it. (do this with both)
Step 4: Stick It in the Hole
Stick the eyebolt through the two drilled end caps, and secure them tightly with the nuts.
Step 5: I <3 Rocky!
place the end caps on the PVC pipe. ( you might want to use some pvc cement for extra stability)
FISH ><)))">
FISH ><)))">
Step 6: [OPTIONAL]
Cut lengths of foam tubing to fit around the nunchuck handles so they don't kill you. and your done!
