PVC Seed Planting Tool / Clod Maker
Intro: PVC Seed Planting Tool / Clod Maker
Spring is coming soon and it's time to start sowing seeds for a successful garden!
The idea here is to build a clod maker easy to make and cheap (even for free with recycled materials in my case).
STEP 1: Supplies
1x 11cm pvc pipe Ø 40mm
1x 13cm pvc pipe Ø 32mm
1x screw Ø 5mm (5cm long) + 1 washer + 1 self blocking nut
1x screw Ø 4mm (2cm long mini) + 3 washers (with the same diameter than the screw's head) + 1 nut
1x washer Ø 32mm
1x piece of plywood (1cm thick mini)
1x something to use as a handle, the ideal would be a pvc T but i used an old curtain rod end.
STEP 2:
bore the Ø 40 pipe with a 6mm drill as shown on the picture. Do the same on the other side.
STEP 3:
draw lines between the the 2 holes and cut (i used a dremel). Do the same on the other side.
STEP 4:
bore the Ø 32 pipe with the 6mm drill (see picture for measure).
STEP 5:
cut the plywood with a Ø 32 hole saw and gather in this order : the Ø 4 screw, 2 washers, the Ø 32 washer, the plywood piece, the last washer and the nut.
STEP 6:
insert the piece of the step 4 in the Ø 32 pipe.
STEP 7:
insert the Ø 32 pipe in the Ø 40 pipe and put the Ø 5 screw. Put the washer and the self blocking nut on the other side but don't squeeze too much, the 2 pipes must slide.
To complete the clod maker, slot the handle on the Ø 32 pipe.
The job is done!!
STEP 8:
Now put some drenched loam on the clod maker, compact well and press the handle to unmold.
All that's left is to put a seed inside the hole and to fill in with a bit of loam.
No need to sprinkle immediately, it's wet enough!
Enjoy!
6 Comments
waterst20 2 years ago
jinn_10 2 years ago
Shawn Harper 2 years ago
jinn_10 2 years ago
For the "storage", i use trays of galvanised shelving turned over and welded to keep water. Advantages: easy to carry and quick to water! (I uploaded pictures on step 8 :) )
snorlaxprime 2 years ago
shalnachywyt 2 years ago
