PVC Yurt
57,284
235
22
Introduction: PVC Yurt
Here's a cheap, easy, and fun solution to your camping shade structure needs! The whole thing will cost you around 200 dollars and an afternoon's worth of pvc cutting. The result? a 12ft diameter, octagonal yurt that fits into a snowboard bag for easy transportation. I used a parachute ($60 included in the total cost) to cover it  which works great as far as size however it is not very breathable so rolling up the sides helps during the day.
Now the fun! because it's so cheap to make, spend a little time on paint (helps with keeping the various parts organized). Also, the roof is almost 10ft in the middle leaving plenty of room for hanging lights.
Detailed plans coming soon!
1 Person Made This Project!
  • Backyard Contest
    Backyard Contest
  • Remote Control Contest
  • Meatless Challenge
    Meatless Challenge
22 Comments
MalinaK
MalinaK
Question 6 weeks ago
Hi! I'm considering doing pvc yurt project and I was wandering is there any specific reason you chose octogonal and not hexagonal shape? I'm asking because there are corner connectors which can be used on hexagonal shapes that seem to be problem for octogonal.
cblum12
cblum12
7 years ago on Introduction
if your worried about the wind you might be able to fill the pipes with sand as you do each section and then put the uprights in the base first then fill.....ok so as i type it starts to sound like a pain, BUT if you needed it stronger and heavier and had the time.....
HardyG2
HardyG2
Reply 5 years ago
....or just add water into the pipes.
1 liter water is 1 kilogram.
50 l = 50 kg...
well you know math.
But obviously, you'll need to close the end of each section.
slivie
slivie
8 years ago on Introduction
Pretty interesting. Nice blue print too. I am wondering why you didn't make the expandable lattice that genuine yurts have. They are lightweight but strong and you wouldn't need big old 2 inch thick pipes. I'm thinking 1/2" pop riveted together in a lattice would be preferable. I loved the parachute idea. The reason I looked this up was I am thinking a yurt frame would make a great green house.
racoontnn
racoontnn
Very interesting version of the yurt! Forward a detailed plan.
skipernicus
skipernicus
This is important: parachutes do not stop the wavelengths of light that cause sunburn. So, you will have shade, but you can still get sunburn!
griddim
griddim
11 years ago on Introduction
this looks perfect! when can we expect the detailed plans?!?!?!
Dr.Bill
Dr.Bill
It is now July 2013 still no plans.....
magnadude
magnadude
10 years ago on Introduction
Simply tie rope in an X between the rectangle areas of the walls. Your problem is that squares and rectangles aren't very rigid, but adding some braces between two opposite corners should work well and save you alot in time redesigning and materials.
MaxQuest
MaxQuest
PVC YURT UPDATE! Important! I have just returned from testing this yurt at Burning man and it was sadly unable to withstand the strong gusts of wind coming off the playa. I was able to keep it up for the first few days using pvc cement glue at the joints but ultimately it collapsed. After being on the playa for the first time this year I see that most structures of this size are made of steal however I am confident this structure will be playa proofed by next year. THE KEY IS THICKER PVC! 2 inch instead of the 3/4. Also i want to look into making a better cover as the parachute catches the wind like it's supposed to. THIS YURT IS STILL SUPER FUN. If you aren't fighting the worst conditions possible it should stay up and provide plenty of sheltered space. I'm broke now so yurt 2.0 will not be in production untill proper funding is obtained.
Helter
Helter
You'll probably get better results by using a more traditional yurt design. Increasing the diameter of the PVC will increase the rigidity of the poles, but your underlying problem is that the joints can't flex, and under high wind/stress they'll need to.
You're also increasing your costs and decreasing your portability significantly.
tricker69
tricker69
Well this post answered my wind question. I wonder how some thicker walled aluminum tubing would hold up. It would still be light weight to carry the whole bundle around. A lot lighter than with a whole wooden wall frame.
busterfan1
busterfan1
This is FANTASTIC! We used an online program to play around with some of the measurements so we're off to the hardware store to pick up supplies. Just a quick question. Where did you pick up a parachute for so cheap?
jfarley3
jfarley3
I have another question, which online program did you use to play with measurements?
SashaDensikoff
someone else has done a yurt with a wood frame.
It may cost a little more, but it certainly looks more resiliant, and the step by step instructions seem to be really thorough. Comes with pictures.
https://www.instructables.com/id/Build-yourself-a-portable-home---a-mongolian-yurt/#step1
Hope it helps. :)
mruland
mruland
Any news on when the detailed plans will be coming? Looking forward to trying this out...looks like something that even I can do...
