Introduction: PVC Target Holder
This instructable will show you how you can create a target holder out of 3/4" PVC for about $10-15. You could also use 1" PVC to make it a little more stout, however it will cost a bit more.
Lets get started with what you need.
Tools:
Hacksaw or PVC Pipe cutter
Measuring tape
Pen or magic marker
3/16" drill bit
Drill or drill press
Knife or scissors
Hammer (optional)
PVC Cement (optional)
Parts:
3 x 10 foot pieces of 3/4" PVC
4 x 3/4" tee
2 x 3/4" 90 degree ell
4 x 3/16" 2-1/2" eye bolts
1/4" flat washers
10 feet of parachute cord or other string/rope
2 x binder clips
I got the idea for this stand from the following site: http://www.alpharubicon.com/leo/pvctstandc.htm
Tools:
Measuring tape
Pen or magic marker
3/16" drill bit
Knife or scissors
Hammer (optional)
Parts:
4 x 3/4" tee
1/4" flat washers
2 x binder clips
Step 1: Cut the Pipe!
The first thing to do is measure and cut your PVC pipe. For this you will need:
Tape measure
Marker
Saw/cutter
You will need to cut the following number of pieces:
2 x 4' long
2 x 3' long
6 x 2' long
To get the most out of your PVC pipe, and even have a spare piece, cut the pipe as described below. Doing so will leave you with a 4 foot piece left over. This will allow you to replace any piece should it be subject to collateral damage.
PVC Pipe # 1: 2 x 4 foot pieces, 1 x 2 foot piece (Total of 10')
PVC Pipe # 2: 2 x 3 foot pieces, 2 x 2 foot pieces (Total of 10')
PVC Pipe # 3: 3 x 2 foot pieces, 4' spare
Tape measure
Marker
Saw/cutter
2 x 4' long
2 x 3' long
6 x 2' long
Step 2: Drill Some Holes
This step involves drilling some holes in the four foot sections of PVC for the eye bolts. I used a 3/16" drill bit in a drill press for this step. Where you place the holes is entirely up to you. You can place them depending on what size targets you'll shoot. I made mine so it would accommodate standard B-27 targets as well as 25 meter M16A2/M4 targets.
I placed my holes as follows:
1 1/2" from the top and bottom
6" from the top and bottom
Try to get the holes as centered as possible. If it's off center a little it'll be okay, it'll just look a little weird. Mine aren't perfect but nobody will know........except for you.
Step 3: Assemble the Pieces!
This step is pretty straight forward. You can glue the pieces together if you want, however the pieces fit fairly snug and it will be impossible to take apart for transporting, and difficult to replace pieces that are subject to collateral damage. I used a hammer to tap the leg pieces into the tee and the 3 foot top piece into the 90 degree ells.
Make the legs:
Take three of the two foot pieces and put them in one of the Tees. Do this twice.
Next put a Tee on top of the two foot piece that is sticking up.
Place a three foot piece between the two legs.
Make the frame:
Take a four foot piece and stick it in the empty hole in the Tee on each side.
Put the 90 degree ells on the remaining three foot piece. This will go on top of the four foot pieces.
Attach eye bolts and parachute cord:
Place your eye bolts in the holes you drilled in the previous step.
Cut a piece of parachute cord a little over 3 feet long. Tie one end to one of the eye bolts. I used a half hitch. Do the same on the other side making sure that the cord is taut.
At the bottom, you will need a piece that is just over 6 feet long. Thread it through each eye bolt and then join the ends together with a square knot. Make sure it is taut before tying the knot.
If you don't know how to tie knots, then Animated Knots will show you step by step how to tie every knot imaginable.
Make the legs:
Make the frame:
Step 4: Go Shoot Em Up! Transport & Storage
When you get to the field just assemble your stand and use the binder clips to hold the top of the target. Place the bottom of the target between the two pieces of parachute cord at the bottom. This will hold the target in place if there is any wind.
When transporting you can just twist one of the four foot pieces and wrap the parachute cord around it. You can wrap all the pieces together with a piece of wire or even put the pieces between the four foot pieces and hold them together with the parachute cord.
The stand shouldn't take up much space when being stored. I just stuck mine inside some shelf brackets along with other short pieces of left over pipe.
