Introduction: PVDRILL - PVC Drill Press
The idea is to build a "Rotary Tool" using low cost elements for routing, cutting, drilling and sanding, mainly PVC pipes. Something like "vertical drill" but simpler...
Picture - Source: Wikipedia
Logical Project (FreeCAD):
- 000-PVDRILL-V2.FCStd
- 001-COLUNA-V2.FCStd
- 001-SUPORTE-V2.FCStd
- 002-SUPORTE-RETIFICA-V2.FCStd
Materials:
PVC Pipes
- 20 mm (1/2") = 1x of 730 mm (28.74")
- 25 mm (3/4") = 1x of 162 mm (6.37")
PVC Fitting Connectors
- 90° Elbow 20 mm (1/2") = 3x
- Tee 20 mm (1/2") = 6x
- Coupling 25 mm (3/4") = 1x
- Cross 25 mm (3/4") = 1x
- Tee 25 mm (3/4") = 2x
Fasteners and Connectors
- Hex Nut (1/4") = 8x
- Flat Washers (1/4") = 8x
- Screws = 2x
Others
- Threaded Rod (1/4") = 1x of 320 mm (12.59")
- PVC Glue
- Wires
- Button
- Motor DC 3V~12V - 20W
- Drill Chuck
Step 1: The Project
I have identified some legal ideas searching the Instructables projects and the internet, so I went along with the idea of creating an outline for this project. A great reference was the design of PVC Dremel Drill Press.
Step 2: Designing
The project was divided into four structural elements: base, column, support and rotary tool. As a rule the possibility of disassembling each element and saving individually.
Step 3: Building the Base Structure
For this steps you need to cut PVC Pipes following this sizes and glue the PVC Pipes and Connectors following the image.
PVC Pipes sizes:
Type 20 mm (1/2")
230 mm (9.05") = 2x
130 mm (5.11") = 1x
50 mm (1.96") = 2x
Step 4: Building the Column Structure
PVC Pipes sizes
Type 20 mm (1/2")
50 mm (1.96") = 1x
230 mm (9.05") = 2x
40 mm (1.57") = 2x
Step 5: Building the Support Framework
PVC Pipes sizes
Type 25 mm (3/4")
18 mm (0.7") = 2x
36 mm (1.41") = 3x
72 mm (2.83") = 1x
Step 6: Building the Structure of Rotary Tool
PVC Pipes sizes:
Type 25 mm (3/4")
36 mm (1.41") = 2x
Step 7: Putting the Complete Structure Together
Everything is prepared to be connected, so let's turn some connections.
Step 8: Assembling the Rotary Tool
To fix the motor I made a PVC holder and soldered the wires.
Step 9: Mounting the on / Off Button
Bonus idea.
Step 10: Last View
Well, first prototype and my first Instructables done. :)
Step 11: Next Steps
- Adjust rotary tool
- Permanent power supply
- Base for fixing
- Vertical control shaft
- Speed control
