Introduction: Pack Cloth Drum
This is a simple drum made from a thick tube and pack cloth using screws, some fishing line and some cord. It doesn't take much time and all of the materials can be found at most department-type stores.
Step 1: Step 1- Cut the Tube
You'll want to cut the tube down to about a foot or a foot and a half so that you can work with it easily.
Step 2: Step 2- File a Groove
Around the top of the drum about half an inch down from the rim, you should file a groove all the way around so that when you tie the pack cloth on, the string has a groove to sit in.
Step 3: Step 3- Attach Screws
You will need to attack four screws to the bottom of the drum. Do not screw them in all the way, leave them out enough so that you can loop fishing line onto them.
Step 4: Step 4- Cut Pack Cloth
Cut out a nice square of the pack cloth and put it over the open top of the drum (not the end with the screws). Cut four tiny holes in each corner of the cloth as well.
Step 5: Step 5- Attach Fishing Line
Cut out four pieces of fishing line about two feet long. Slip the fishing line through the small holes in the pack cloth and then loop the line down around the screws and tie a couple knots in the line to make sure it stays secured around the screws.
Step 6: Step 6- Tie String Around Top
Take a long piece of string and tie it around the top of the drum. Make sure that the string is securely lying in the groove that you filed. Tie the string tightly so that pack cloth is taught.
Step 7: Step 7- Decorate!
Now that your drum is essentially done, you can decorate it any way you want!
