Introduction: 2-Player Pacman Arcade Machine
I am a 9th grade student at Kirkland Ranch Academy of Innovation and I made a 2-player Pacman arcade machine. The goal of the game is to collect more pellets than the other player, and you can eat a power pellet that allows you to eat the other player and steal some of their score.
Fusion 360
Step 1: Create the Base of the Machine
Create a new sketch on the horizontal plane.
Choose 2-point rectangle and make it 105mm wide and 100mm long.
Extrude it out 100mm high.
Step 2: Create the Controls
Create a new sketch on the side of the cube and choose 2-point rectangle.
Make the rectangle starting in the top left corner and make it the width of the box and 30mm down.
Extrude it out 40mm.
Create a new sketch on top of the structure and choose the circle.
Create 2 sketches towards the center with a diameter of 10, which will be the buttons.
Extrude them out 2mm.
Create two more circle sketches to the left and right of the buttons with a diameter of 5.
Extrude them out 15mm.
Create spheres on top of them and type in 13mm.
Step 3: Create the Top of the Machine
Create a sketch on top of the machine and choose "Line".
Make it go around the back 3 sides of the machine with a thickness of 8mm and extrude it out 100mm.
Create a new sketch at the top and make it 20mm thick.
Extrude it out 92mm to line up with the sides.
Create barriers to the side of the controls as shown in the image by using the fit-point spline.
Create a new sketch on the back inside of the machine and extrude it 40mm towards the opening.
Step 4: Create the Game
Create a new sketch where the screen would be and create random square shaped obstacles.
Create Pacman by making a circle then cutting out a triangle in the front.
Do this twice in different places.
Make a bunch of circle sketches with a 1mm diameter in between the obstacles.
These will be the pellets that Pacman eats.
Extrude all of these sketches out 1mm.
Step 5: Make Coin Slots and Design
On the front bottom of the machine, create 2 new sketches of thin rectangles and cut them into the machine 10mm.
Create rectangles right next to those and extrude them out 1mm. These will be the coin slots. If you would like, create a rectangle around the coins slots and extrude it out .2mm.
On the sides of the machine, create new sketches of circles with a diameter of 35mm, extrude them out 2mm, and cut out a triangle in them both.
Below that, make 2 sketches of Pacman going towards each other with small circle sketches in between as the pellets.
Render all of the aspects of the machine.
