Introduction: Paint Calendar
Materials:
-8.5 in. x 11 in. picture frame
-Paint Sample cards; feel free to be creative with colors (they are free and can be found at any store that sells paint)
-Any type of adhesive
-Dry erase marker
-Sharpie
-Printer paper
-Scissors
-Ruler
-Pencil
Step 1:
Remove cardboard from the picture frame.
Step 2:
Glue printer paper to cardboard.
Step 3:
Select 7 paint sample cards of your preference.
Step 4:
Using a ruler cut off half an inch vertically from each paint strip column.
Step 5:
Use scissors to cut top and bottom color block off of the 7 sample cards you have chosen. (When cutting the blocks, cut in the middle of the white line). There should be 5 blocks left on paint strips once this step is completed.
Step 6:
Save the darkest color block form each paint strip. Discard the lightest color block
Step 7:
Cut each of the darkest color blocks hot dog style (these will serve as the days of the week). Discard one half of the cut paint block.
Step 8:
Move the darkest color block (that was cut in the previous step) to the top of the column, above the lightest color. (as seen in the picture)
Step 9:
Place each color strip on the cardboard paper, positioning strips in accordance to your preference (as seen in the picture).
Step 10:
Aligned bottom of color strip with the bottom of the paper.
Step 11:
Glue each color strip and the separate dark color blocks to the paper, with the dark color block being above lightest color block of the same strip.
Step 12:
Write the days of the week with sharpie on the top dark color blocks (depending on your cultural background).
Step 13:
Reassemble picture frame.
Step 14:
Fill in calendar accordingly with dry erase marker.
