Paintball Grenades
Intro: Paintball Grenades
Re usable, cheap paintball grenades and are easy to make
STEP 1: Materials
1.Sergical tubing (I got mine from a friend who was in physio tharapy and my brother got some also from a physio tharapist but im sure theirs other places to get it)
2. Coat hanger (straightened out)
3. Air soft BBs (the 6mm ones, it shouldn't matter what weight)
4.Paintballs
5.Water gun pump(out of the gun). Iv also used nerf gun peices but their harder to use.
4.Paintballs
STEP 2: Tubing Length
Cut the tubing into peices that are around 10 or 11cm
STEP 3: Tying the End
Tie a knot in one end each peice of tubing so that the one end is sealed. make sure that it is tight and close to the end.
STEP 4: Make the Collar
Cut a peice ooff the open end of the tubing to creat a small ring to tubing. Take this and put it over the tube near the end.
STEP 5: Pin Hole
Using a pin, make a hole just above the collar for the safety pin to go in
STEP 6: Getting Your Paint
Take the paintballs and put them in water for a few minutes. After you take them out they should be soft. Cut them open with a knife of scissors and squeeze the paint into a disposable containter. Iv also heard that you can boil them. Iv never tryed it my self but it might work.
STEP 7: Filling the Grenade
Put the open end of the tube over the end of the pump as far as you can. Fill the cylinder with paint and push the paint into the granade with the plunger. If you have a pump from a water gun it should have a valve in it but if it doesnt you have to twist the neck of the grenade befor you take the plunger out to fill it again. Fill the grenade with two pumps of paint and one of water (to save paint). If it gatheres in the middle push it to the sealed end.
STEP 8: Putting in BB
Twist the neck of the tube just above where the paint is so that its sealed off. Pull the tube off of the pump while keeping it sealed. It should not leak. Take one BB and push it into the tube till it is just below the collar.
STEP 9: The Safety Pin
This should have been made befor putting the paint in the grenade but i can figure out how to insert steps. Using plyers make a safety pin out of coat hanger. To brake the coat hanger just bend it back and forth several times fast and it'll break. If you want you can also add a ring to the pin. Once the the grenade is filled and you've put the BB in, keep it sealed and push the safety pin through the hole you made above the collar. After this you should be able to un twist the neck and your finnished.
STEP 10: How to Use It
To use the grenade carefully pull out the safety pin and throw. What should happen is when the pin is in any extra pressure in the grenade pushing against the BB (like the pressure from dropping it or bumping it while running) will try to push the BB out but the pin will stop the BB. When you remove the pin, as long as your carefull the BB will stay in the neck of the grenade and the collar will help it stay there. When the grenade hits something the extra pressure will push the BB out and the paint will be sprayed every where in the area. The pressure for tube will cause the grenade to spin so the paint should sray all around. If you keep the pin and find the empty grenade you can re-fill it, put a new BB in and you can re use it. The splatter zone (area that the paint covers) varies but is usally around or over 1.5 meters. Have fun!
219 Comments
Sussysalamander 9 months ago
lukee1986 6 years ago
difference between making these and using waterballons will it work
Prop 6 years ago
rocketdork 17 years ago
ManchesterUtd. 14 years ago
Prop 14 years ago
burke.harris 7 years ago
Oh, well i dont know what to say. i got mine at home depot
Prop 14 years ago
rockadio101 13 years ago
codongolev 15 years ago
Prop 15 years ago
naruto the ninja13 14 years ago
Prop 14 years ago
Prop 15 years ago
noahmadd 8 years ago
If You don't have a water gun pump you can use a 60ml plastic syringe.
JulianAzz 8 years ago
I like it!
Trolling paintballer 11 years ago
The Greene 11 years ago
