Introduction: Painting a Dresser to Give It a Custom Look
Do you have an ugly dresser or piece of wood furniture you can't stand to look at but can't bear to part with? Before you get rid of it, think about the potential it can provide with a new look. Try painting it in your favorite colors to make it a nice statement piece for your room.
Step 1: Gathering the Materials
After several years of scraping, sanding, and painting furniture and lots of trial and error, I have found the best products and techniques that work for me. There are many great products and different ways to get similar results, but the following instructions were used to complete this painted finish. For additional information: http://a4wardthinker.hubpages.com/hub/How-to-Faux-Paint-an-Ugly-Dresser
- Drop Cloth
- Two Colors of Latex Paint - 1 quart ea.
- Stain
- Minwax Fast Drying Polyurethane Clear Satin Finish
- Elmer's Carpenter Wood Filler
- 2" Foam Brush
- 1 1/2 -2" Disposable Brush
- Putty Knife
- Rock
- Nail Set
- Chisel
- Nitrile Gloves
- Rags
- 220 Sand Paper
- Palm Sander
Step 2:
Remove drawers from dresser, hardware, and any undesirable pieces attached to the dresser. Yes! You can remove curved toe kicks, scallops decorative strips, or any piece you can remove with a putty knife. Just push the knife between the dresser box and the decorative strip and gently tap the end of the knife with a hammer until it can be pulled off. Use wood putty to fill any nail holes or cracks. When the putty (wood fill) dries, sand it smooth and flat. To prevent a dip in the fill, put on a little extra so it covers it when it is time to sand it off. Wait! Not too much. You will be there all day. Work smarter, not harder right? Lightly sand with 220 grit sand paper or pad to give the surface a light scratch coat. That means 1 or 2 passes across the surface with the sand paper and that is it. Wipe off any dust before painting.
Step 3:
Paint your dresser with 2 different shades of one color choice. To save money, I used a shade of blue and added a little white to make my second color shade. Use one color as your primary color and the other as your secondary color. I thin my paint so it blends colors better and easier to sand when it dries. Brush paint randomly over the most of the dresser but leaving wood exposed in different places. Use a rock with rough edges to randomly create nicks and dents. Turn the rock as you go to create different marks. Use the nail set to create worm holes in different areas.
Step 4:
After paint dries, sand the dresser with 220 grit sand paper using an electric palm sander. This is to blend paint together, sand off painted edges and bare spots. Sand sharp edges and corners to give it a worn aged look. This step makes a big difference in appearance so you can add your creative touch. Wipe off all dust. Apply stain with a rag and wipe off excess immediately with a dry rag. Allow stain to dry over night. Apply 2 - 3 coats of clear finish allowing each coat to dry between each application. Apply new hardware to give it a personal touch and new look. For additional information: http://a4wardthinker.hubpages.com/hub/How-to-Faux-Paint-an-Ugly-Dresser
