Pallet Planter
Intro: Pallet Planter
Use pallets to make planters or plant pots.
STEP 1: Basic Frame
The worst bit is first. Take apart a few pallets and de-nail them. I used a Pallet Reclamation Bar.
Cut 4 legs the same length.
Cut 8 side bars to the length you'd like the width of your planter.
STEP 2: Frame Assembly 1
Build two matching sides as pictured.
The lower side piece shouldn't touch the ground to avoid water, I left around an inch free.
STEP 3: Frame Assembly 2
Use the 4 remaining side pieces to construct a very simple cube. I used screws for this whole process.
STEP 4: Side Panels
Cut side panls from pallet boards. You'll need a load if you're building a big planter like this.
Since I was using lots of different pallets here, I attached the boards in a random order to give it that rustic look.
I used nails for the sides as they look nicer and aren't load bearing. Try and re-use the nails you took out of the pallets if they're straight enough
STEP 5: Top
When you're done with the siding, cut four more pieces for the top as shown.
Cut these pieces at 45 degrees to make a nice looking top.
STEP 6: Done
These planters would rot pretty quickly if I put soil in them (not to mention I didn't build a bottom).
Instead, I used an old bin to put the plant in. Hopefully whatever you plant will hide a bit of the bin or barrel.
The other pictures show another planter I build from half a leaky water butt.
15 Comments
jsakutu 9 years ago
spectaculareyedcat 10 years ago
sladek 10 years ago
Devenger 11 years ago
Otherwise I would recommend something like an old scrap from a swimming pool liner and caulk, if you want to save some money. A rubber membrane can be bought new at most Lowes and Home Depot stores too, if that is hard to come by.
spylock 11 years ago
envirolutionary 11 years ago
peterbryenton 11 years ago
sladek 11 years ago
racoontnn 11 years ago
Gareth0123 11 years ago
sladek 11 years ago
Eye Poker 11 years ago
http://www.organicauthority.com/sanctuary/repurposed-wood-pallet-toxic.html
sladek 11 years ago
audreyobscura 11 years ago
