Introduction: Pallet Playhouse
Want a fun project that won't cost much? Got kids and a decent amount of time on your hands?
Try using shipping pallets and reclaimed wood to build your kids a funky playhouse. Or use it as a shed.
Not only was this project fun, I also traveled a lot and met a great many very nice people who were giving perfectly good materials for little or no money.
I spent $200 dollars on this project in 2008-2009. Over a hundred dollars went to paint, the rest to any building materials I couldn't get for free.
Take a look at the pictures. Spend a lot of time on your ideas and then start collecting those pallets!
Step 1: Break Down the Pallets
I got about 80 pallets, five at a time, from my work.
I got a chance to know the facilities people and they were very happy to let me take them. It saved them a trip to the dumpster and saved them from having to pay to have the dumpster emptied.
That's right. Almost all of these pallets go directly to a landfill. The rest are picked up by pallet salvage guys (they get $1 or so a pallet) and people like me. Many people burn pallets for heat.
I got a great deal of exercise carting the pallets out to my Jeep. I could fit about eight at a time, but I rarely found more than five good ones on any given trip.
A few words about pallets:
There are all sorts of them. Some are oak, some are pine or spruce. Some of them are even mahogany or cherry or cedar.
Stay away from the hardwood pallets. They"re almost impossible to deal with in large numbers. They are just too darn tough. Unless you're doing something small or you want them for fire wood (They are awesome for that), stick with the pine or other softwood pallets.
About one in ten of the ones I found were high enough quality. Most were garbage. I tried to find ones that were brand-new, roughly 48" x 34", and were constructed of (3) notched 2'x4's connected by 3/4" inch nominal boards (commonly called "one by" lumber.) All of them were heat treated (marked "HT") and held together by nearly indestructible spiral nails.
Many people assume that pallets are pressure-treated. In my experience, very few, if any, have had any sort of treatment besides kiln-drying. I'm told that years ago they were also treated with pesticides, but this is no longer the case.
Step 2: Cut Off the Stringers
I started by cutting off the outside stringers (the 2x4's) with a skill saw. Trying to remove the spiral nails without damaging the wood was impossible.
You'll want to set your depth at a fraction more than the 3/4 inch board.
Step 3: Cut Off the Stingers, Continued.
After you cut along each outside stringer (not the middle!), flip the pallet over and do the same on the other side.
WARNING: Pallets are usually made of the lumber that got rejected for other uses. It's hard, often warped, has old broken nails imbedded in it, and generally is just a pain to work with. Be careful. Wear goggles. Repetitive work breeds carelessness. Trust me, I know.
Use a hammer to knock the stinger off if it's stubborn.
Step 4: Detach the Board From the Middle Stringer.
You'll be left with a bunch of 1X4's and 1X6's attached to the 2x4 in the center.
By rocking the 1x4's and the 1x6's back and forth, you can get the board off without totally destroying it.
There were still be quite a few ruined boards. Good for the woodstove.
Pull or remove any nails left in the board and stack it to the side. I ended up having to rearrange and move my stacks of boards quite a few times as the pile grew. Think ahead. There's going to be a LOT of stuff in your garage/shed/backyard. You may also want to grade your boards, based on knots, warping, bark, etc. This will help later when you try to decide what to use for what job.
Save the nails, too, if they're straight. The blunt spiral nails are really the best type of fastener to use when you're attaching the 3/4" lumber to your playhouse. They minimize splitting. You'll be amazed at how many you end up keeping.
Step 5: The Pay-off
I got about (6) good 1x4's and (3) good 1x6's per pallet. I also got a (3) 4' lengths of 2x4.
Notice the ends are ragged-- I paid for that later when I made the siding. I had to re-square every board.
Step 6: Salvaging the 4' 2x4's
I smashed off the wood with the hammer, then yanked the nails.'
Every 2x4 had at least one nail with a stripped off head. I cut them off with an old pair of linesman's pliers.
People have suggested to me that using a sawzall to simply cut the nails was a better way. I _did_ try it, but I decided on this method as being the best. Your mileage may vary, depending on exactly what kind of pallets you want to use.
Step 7: The Long Winter
I spent most of a New England winter collecting and breaking down pallets. I also trucked around two states picking up lumber, doors, nails, heck anything people would give me for free. As I menttioned, I met a lot of nice people and saw a lot of towns I otherwise wouldn't have ever known about.
I work pretty far from home, so I got to concentrate on two different areas as well as map out my "no fly" zone based on my long commute. Most of the time, I stayed very close to my normal work/home route. This is important if, like me, you're looking to build an environmentally friendly structure. Doesn't make much sense burning thousands of gallons of gas building a recycled playhouse!
Step 8: Building the Windows
Between collecting and breaking down pallets, I spent a lot of time building the double window and the diamond-shaped porthole for the playhouse.
I have a garage, but it's not heated. Sometimes it got pretty cold!
A few words about tools:
At minimum, you'll need a circular saw, hammer, crowbar or catspaw, and heavy cutting pliers. A handsaw will come in handy, too. A sturdy ladder is a must.
By far the most useful tool I had was my tablesaw. It's not necessary for the house itself, but without it I wouldn't have been able to make the siding. It also helped a lot on the windows and as an all-around tool.
But....you could get away with the circular saw, miter box, and a handsaw. Or replace the methods I used with ideas of your own.
The first step for the windows (two for the "ice cream window" and one for the porthole) was the basic frame. My idea was to take some old storm windows I had from my house and frame them in 1x4 pallet wood. You could use plexiglass or old glass from sashes, or even simple screening material.
I started with a long rabbet on the side of a 1x4. It took two cuts on my table saw, one for the depth, the rest for horizontal area. If you have a dado or a router, you could dig the rabbet out with that.
Step 9: Building the Windows, Contnued
I had these old storm windows left over from when we replaced some double-hung windows on the house.
Step 10: Frame for the Windows
After the sides each were rabbeted, I cut 45 degree angles on each side, exactly like you would when building a picture frame.
I made the miter sled years ago. Makes it much easier, but you could use your circular saw, a miter box, even the handsaw.
Step 11: Frame for the Windows, Continued.
Ta-da. The basic building block for the windows.
I'd say you don't want the rabbeted-out groove to be too tight-- I get a feeling that the wood expanding and contracting would crack the pane pretty easily.
Step 12: Frame for the Windows, Cont.
Step 13: Frame for the Windows, Cont.
I finished the double windows by backing the frame with more 1x4's. I just butted them together.
The first picture shows the first two boards (horizontal, in the background and foreground. The board perpendicular is shown in the proper position in picture number (2). I put two 1" wood screws in each corner, driven straight through into the undelying frame. You'll want to countersink them.
Step 14: Building the Double "ice Cream Window"
Here they are, complete and ready for their casing. This will be the front, gable-end double window.
Step 15: Ice Cream Window, Continued
I built a frame for the whole works out of some 2x6 lumber a nice guy in a nearby town gave me. He posted it on Craigslist and gave me a whole bunch of 2x6's, 2x8's, and 2x10's. The joints are simply butted and screwed together with two inch deck screws.
The "hinges" are pieces of an old dowel I had. '
I would later build a rough opening for the whole thing, slide it in, and fasten it with long screws into the playhouse. I measured ahead; the overall depth of the window matched combined width of the framing, the siding, and the interior paneling. It was a simple matter to attach mouldings to the exterior and interior when it was time for the finish work.
I also later added two handles, some wood strips to make it weather-tight, and a simple hook and eye lock to keep it shut when not in use.
If you look at the finished product in the later photos, you'll see that there are also wooden "x's" in each pane. These were simply glued, directly to the glass.
Step 16: The Diamond-shaped Porthole
The diamond window was easy. I made the frame the same way, then cut a diamond shape and screwed it to the top. I glazed it later on with some old window putty to make it water tight.
Step 17: Finally-- the Real Work! the Playhouse Floor/deck.
I finally got tired of fooling around in the garage and decided to get started. It was cold (February), but I was eager and full of energy after being shut up all winter.
I salvaged a bunch of old 4x4's and set them on some bricks and cinder blocks (all free). I built a 8x10 square from reclaimed pressure-treated 2x4's I got from a guy who had torn down his deck. He posted them on craigslist and I've been using them for every single project I've done over the last few years. He gave me almost 500 linear feet of 2x6's!
I leveled the whole thing by adding and removing bricks. You'll want to do that under the 4x4's.
When it was close, I laid across the pallet 2x4's using the center 4x4 as a stringer. This worked very well as I did not need to cut any of the 2x4's-- I simply laid them side to side.
Notice the funky pallet 2x4's in the picture-- they have small, half-oval sections missing. This is where you would slide in the pallet jack.
The overall area is approx. 8x10. The playhouse itself is 8X8, the two-foot protruding section is the where the deck will go.
Through out the build process, I constantly had to adjust spacing and the like to accomodate the roughy 4-foot 2x4's and 30" 1x (one by) lumber.
I had various pieces of plywood for the floor, but I also had to make sure that the floor joists were no further apart than 15", in case I had to use any of the 1x6's. Why 15"? Because the short lengths of lumber need to have an alternating "butt" end, much like brickwork. A long, continuous joint would be too weak. By alernating, you add strength.
Step 18: Floor, Continued
The particleboard came from....what else? Pallets. I actually grabbed a bunch of them just for the 3/4 inch particleboard. The underlying wood, the 2x4's and the 1x's weren't really up to par (they were oak and hard as granite), but I found a use for them here and there.
The particleboard caused me some concern later when it began to rain. I thought they'd fall apart, but they actually held up well.
You can see the middle beam where the 2x4's meet really well in this picture. I toe-nailed all the 2x lumber to the 4x4's, every two feet or so. This is important-- I may want to move the whole structure at a later date.
Step 19: Framing
The frame goes up.
I actually ended up running out of 4-foot pallet 2x4's and purchased approx. (20) bargain 2x4's for a dollar each. They weren't exactly straight, but for $20, it wasn't bad.
Notice the 2x6 and 2x8 headers. This was more free wood I got off of craigslist.
There are 2 doors, one in the front, one in the back. In this photo, you can see the rough opening for the diamond-shaped window and the front door. The 2x4 at the bottom of the doorway was sawed out later.
The 2x4's, spliced together and ugly, are 15" inches apart. This is because the siding will be 30" pieces of 1x4, with a staggered vertical seam.
If you need some help with basic framing, check out google-- there are some great sites out there. Basically, though, you should worry about optimizing the material you have without sacrificing safety.
The tarp was to keep everything dry until the roof went up.
Step 20: Framing, Continued
I never imagined just what a pain in the butt it would be to splice (scab) the 4-foot 2x4's together. The wood was really hard and overall it just was not fun. I gave up on anything being square almost immediately.
Because I planned on siding the playhouse with the 30" pallet 1x4's and 1x6's, each stud was placed 15" on center, rather than 16". This allowed me to stagger the vertical joints.
Step 21: Ice Cream Window Framing
This header is most likely overkill, but I wanted a very large opening. Some day, when the kids outgrow this, it'll be converted into a garage for a riding mower. This will give me a _very_ large door!
It is dimensional lumber (ie, it really is 2" thick and 6" wide, not 1.5" and 5.5"). There are two pieces sandwiched together.
Step 22: The Roof
I built this little stand to hold the ridge beam. In most houses, the ridge board is just a place to nail the rafters to. They don't hold weight. This was setup as a true beam to help bear some of the roof's weight.
I got the beam from a guy on craigslist. He gave me a bunch of old dimensional boards he tore out of his attic.
Step 23: Roof
There are a number of web sites with rafter calculators out there, so I won't go in to measurements.
I spaced the rafters evenly, at 16", because I planned on using regular old OSB plywood.
You'll notice that there is a two foot overhang attached to the main roof. I also put joists in the deck. The fascia is a ten foot board that helps to hold the over hang.
As you can see, the windows are in. I made sure they were square.
Step 24: Siding
How to side the play house was a problem I chewed on for a while. I didn't want to just butt the 1x4's together since that wouldn't be even close to water tight.
I finally decided to make my own shiplap siding. It installed with the "inside" edge above the "outside" edge. See the picture notes.
I have a dado blade for my table saw. Two cuts on each board. About 200 boards.
Let's just say it was something I regretted around board number 75. The second photo shows two pieces of siding together.
Step 25: Siding, Continued
It's always nice to have some help. This is my father-in-law. He thinks I'm nuts, but he loves a challenge.
The shiplap is installed with the inside edge on top, outside edge on the bottom. This ensures that rain is kept out and channeled away by gravity.
The vertical butt joints were staggered to add strength, much like the pattern you'd see in bricklaying. They should always meet on a 2x4 member.
I used two nails per board for the 1X4, one on each side, and four nails for the 1x6's, two to a side.
The corners of the structure are rough-- they'll be covered over with vertical moulding.
Step 26: Roofing Time
Time to lay the roof deck. This is 5/8 OSB, rated for roofing. It was about $8 a sheet.
I also bought (3) 10-foot sections of drip edge at Lowe's, for about $7.50.
If I waited around long enough, I could have gotten them for free off craigslist, I'm sure, but I was pretty happy with the very low amount of cash I'd had to spend.
If you look in the front door, you can see that the back wall is not pallet lumber. I ran out by this point and ended up using some very nice 1x10 boards my father-in law dug up at his place. They were shelves, 20 years ago. He has stored them under his porch, along with some vintage, turn of the century 6" mouldings, but he didn't forget about them.
If you look at the rough door opening, you'll see that the left edge is very narrow (see note). This was probably the biggest framing mistake I made. Because it was so narrow, I had to rip the beautiful 6" moulding down to 4", plus I had to shiplap behind it with tiny little pieces of siding. I should have framed the door out at least 8" from the corner.
Step 27: The End.
Here it is, the finished project.
The shingles were free. My nephew had them left over from a job and very nicely donated to the cause.
The mouldings, as I mentioned, were from my father-in-law. They really made a difference.
The four-panel front door was a six-panel door I got from a guy on craigslist. It was brand new!
I cut the little side rails from scrap fence pickets.
We spent a whopping $120 on paint. This was by far the biggest expense, but I am a firm believer in quality paint. Don't forget a LARGE bucket of exterior wood putty (no more than $8.) Just about every piece of siding had holes from pulled nails.
I later put a laminate floor down and paneled the inside in pegboard. We added some decorations here and there and the rest is history...
Step 28: The End, Continued....
You can see the 1X10's here. I did actually cut a shiplap edge in each board so it would be water tight.
The cornerbeads were salvaged materials, craigslist, of course.
Step 29: Back Door
Here's the back door. I made it from an old fence panel. I used the final dregs of the 1x4's and 1x6's on the inside, installed perpendicular to the vertical pickets.
My father-in-law had the door knobs. I made a threshold later on, to cover the ugly place under the door.
Step 30: The Side
Step 31: Interior
The floor was reclaimed from a project on the main house. It's laminate.
Step 32: Some Other Ideas--pallet Doghouse
I bought the shingles for $10 a bundle off Craigslist. No freebies this time, unfortunately.
I incorporated some improvements here, the biggest being that I installed gable vents on the roof. I made these from pallets as well.
Total cost for this project was only about $35. This time, I used some old, leftover paint.
Step 33: Some Other Ideas: Pallet Adirondack Chair.
I believe it was three pallets per chair, plus 30-40 screws, some putty, and some glue.
UPDATE: Just finished the pallet adirondack chair intsructable. Check it out:
www.instructables.com/id/Pallet-Adirondack-Chair/
