Introduction: Pallet Wood Coat Rack
Here is a great looking coat rack made from a few pallet boards with a natural edge and metal hooks.
Step 1: Material / Tools
This coat rack can be made with just a few pallet boards of your liking. I chose the ones I used specifically for the natural edge they offered. It could also be made with straight edges.
To make this you will only need minimal tools
Tape Measure & Pencil
Saw - Jig, Hand, Miter or Table - Whatever you have available
Sander - Hand, Power, Palm, Random Orbiting, Belt - You decide
Drill with bits and screws
Glue - if you want to
Metal Coat Hooks found on Amazon
Step 2: Prepare & Layout
I chose the boards I wanted to use, sanded them down and cut them to size. The size of this project can vary, depending on the size of the metal coat hooks you use and the space you have available.
I laid out the boards to my liking before attaching them with screws from the back, side and top. However, the screws were silver and stood out so I painted them black to make them blend in better.
Step 3: Finish
I applied a clear semi-gloss finish from a spray can. I wanted to maintain the natural look of the wood. After it had dried I attached the metal hooks, pre-drilling the holes first.
Then I hung it on the wall next to our entry door. I did have to put two screws through the board into the studs behind the wall. They are not as noticeable with the existing holes in the pallet wood.
Now it's ready for your spouse to decorate as she pleases.
