Introduction: Pallet Wood Table With Hidden Cooler
This side table is built like a tank and is designed to be outside. Its made by layering and twisting pallet wood. A section of the center has been routed out to accommodate a cooler in the center. To add a bit of whimsy a flock of origami birds are stenciled on the top.
Dimensions: Each layer was 16" x 16". The total height with the top was a little over 20 inches.
Quick Build Notes:
- Each layer was twisted 3/4 of an inch and glued and screwed in place
- Build up a couple of layers then start with the hole for the cooler
- Give yourself some space for the cooler. Cut the hole so its 1/2" bigger than the diameter of the cooler
- For the last cooler layer
- make it the same diameter as the cooler
- cut inside the scribed circle
- file to the circle mark until the cooler just fits in there
- Use expanding foam to hold the cooler inside the hole. Just make sure you remember it EXPANDS A LOT
- When you install the hinges for the top make sure the screws will not go through the wood. I had to cut some of the screws down so they wouldn't blow through the other side.
- I used the following designs to make the stencils
- Use tape to help place where the birds will be. I used different size tape to symbolize the different sizes of the birds
- I used acrylic paint and a shoe shine brush but next time I'm going to use spray paint
- I sanded the first layer with 220 grit sandpaper to fade them a little to give it depth.
- If your lines aren't as crisp as you like then use a knife to scratch away the paint a little
- Several coats of polyurethane were used to help make it weather resistant. Spar Var is a good choice for outdoor use also.
- Use cool packs and not ice since there is no drain for the 1 gallon cooler (originally designed for cold water)
Now when you run out of a drink you don't have to get up as often. Another bonus is this thing is so heavy its not going anywhere :) (unintended bonus feature)
