Introduction: Pandahall DIY Project - How to Make Handmade Wire Wrapped Couple Rings
Wanna make some handmade couple rings for the coming Valentines’ Day? This tutorial will share a couple of DIY wire wrapped rings to you all. Hope you’ll like them~
Step 1: Supplies You’ll Need in DIY Wire Wrapped Rings:
1.5MM Silver Aluminum Wire
0.5 MM Silver Copper Wires
6x6x5MM Acrylic Rhinestone Beads
Round Nose Pliers
Needle Nose Pliers
Side Cutting Pliers
White Glue
Step 2: Make a Basic Wire Knot
1st, cut 2 pieces of aluminum wire and fold then in half, then make a knot with the 2 pieces of wire as pictured;
2nd, cut 2 short pieces of copper wire and wrap them to both sides of the aluminum wires, then cut off the excess wires.
Step 3: Finish the DIY Wire Wrapped Rings
1st, twist the aluminum wire pattern into a ring shape and make a loop at both ends of it;
2nd, cut 2 short pieces of copper wire again and wrap them to both ends of the ring as pictured;
3rd, add a red acrylic rhinestone bead to middle of the ring with glue.
Step 4: Here Is the Final Look of the Handmade Couple Rings.
I make 2 handmade couple rings as picture show to you, do you like them? You can make such 2 handmade couple rings for the coming Valentines’ Day. Have a nice try~
This project is inspired from http://lc.pandahall.com/craft-ideas/12564.html.
