Introduction: Pandahall Tutorial - How to Make a Two-layer Wide Beaded Bangle Bracelet at Home
Do you love DIY bangle bracelets? In today's DIY project, I'll share a two-layer wide beaded bangle bracelet with you. Hope you like it.
Step 1: Materials and Tools Needed in DIY the Wide Bead Bangle Bracelet:
6mm White Round Pearl Beads
4mm Golden Round Beads
3mm Black Tube Beads
2mm Silver Round Seed Beads
0.3mm Tiger Tail
Silver Slide Lock Clasps
Silver Jump Rings
Stainless-Steel Scissor
Needle Nose Plier
Step 2: Make the First Part of the Wide Bead Bangle Bracelet
1st, cut a piece of 0.3mm tiger tail. Then, thread about 28 2mm silver seed beads to it;
2nd, cross the two tiger tails through a 3mm black tube bead;
3rd, thread a 4mm golden round bead to the two tiger tails respectively. Then, cross the two tiger tails through another 3mm black tube bead;
4th, repeat the 3rd step 20 times;
Step 3:
5th, thread about 28 2mm silver seed beads to the bottom tiger tail. Then, cross the tiger tail through the rightmost black tube bead;
6th, cross the two tiger tails through the golden round bead respectively (as shown in the picture);
Step 4:
7th, thread 6mm white round pearl bead to the upper tiger tail. Then, cross the tiger tail through the adjacent golden bead (as shown in the picture);
8th, thread 6mm white round pearl bead to the bottom tiger tail. Then, cross the tiger tail through the adjacent golden bead (as shown in the picture);
9th, refer to the 7th step to add 19 white pearl beads to the upper tiger tail. Then, refer to the 8th step to add 19 white pearl beads to the bottom tiger tail (as shown in the picture).
Step 5: Make the Second Layer of the Wide Bead Bangle Bracelet
1st, cross the two tiger tails through the second black tube bead (from right to left);
2nd, thread about 10 2mm silver seed beads and a 4mm golden round bead to the two tiger tails respectively;
3rd, cross the two tiger tails through a 6mm white round pearl bead;
4th, thread a 4mm golden round bead and about 10 2mm silver seed beads to the two tiger tails respectively. Then, cross the two tiger tails through the 5th black tube bead (from right to left) (as shown in the picture);
Step 6:
5th, refer to the above steps to make 5 more such bead patterns(as shown in the picture).
Step 7: Connect the Two Ends of the Wide Bead Bangle Bracelet Through Silver Slide Lock Clasp and Silver Jump Rings.
Step 8: Here Is the Final Look of the Wide Bead Bangle Bracelet.
What do you think of this wide bead bangle bracelet? It looks very elegant around the wrist, right? The beading techniques used in this DIY project is not very difficult to grasp. If you're interested in this wide bead bangle bracelet, you can try to make one for yourself or friends.
