Introduction: Pandahall Tutorial on How to Make a Yellow Seed Bead Necklace With Jump Rings
This tutorial will show you a personalized jump ring necklace with yellow seed beads. Follow me to see the details together now~
Step 1: Supplies You’ll Need in Making the Yellow Seed Bead Necklace:
Step 2: Make Several Seed Bead Jump Ring Patterns
1st, add 4 yellow seed beads to a jump ring, and this is the basic seed bead jump ring pattern;
2nd, repeat the 1st process to make other more such patterns with yellow seed beads and jump rings as pictured.
Step 3: Connect All the Jump Ring Patterns Together
1st, connect 2 jump ring patterns with a small jump ring;
2nd, connect other 2 jump ring patterns with the first 2 through 2 small jump rings and please notice the situation of the yellow beads;
3rd, repeat above steps to add the rest jump ring patterns through small jump rings as pictured.
Step 4: Finish the Jump Ring Necklace
1st, take 2 small jump rings as one part and connect each part together;
2nd, add a small jump ring patterns to both ends of the necklace;
3rd, add a jump ring to one end of the necklace while add a spring clasp to the other end of it.
Step 5: Here Is the Final Look of the Yellow Seed Bead Necklace.
Do you like this fresh and simple yellow seed bead necklace? You can wear it on hot summer and I think it will be really cool. Just have a nice try!
This project is inspired from: http://lc.pandahall.com/craft-ideas/12294.html.
