Introduction: Paper 2 X 2 Rubik's Cube
This project is paper 2 x 2 Rubik's cube. It's functional and its cool so you can made by yourself in times when you can't get out to buy a new one.
For this project you will need:
- 8 paper sheets
- red, orange, blue, green & yellow color pens
- a needle & a thread
- a tape or a glue
Step 1: Cutting and Coloring the Templates
From the picture above there's a template for the cube, you can print that and cut it or you can draw them by yourself. You need 8 of the cube nets. For the another 8 picture above is shown how to color the cube nets.
Step 2: Connecting and Sewing the Cubes
For the cubes to be sewed first you need to put the cubes in the right order. The cubes that are on the first layer you sew the in upper inside corner and those cubes then you sew with diagonally opposite cubes on the second layer with the lower inside corner. Then you connect them and you scramble a little bit so the cubes won't fall.
Step 3: Moving
The cube is really fragile so you should be gentle. On the video you can see how to move the cube.
