Introduction: DIY Crafted Paper Basket: Made From Waste Newspapers
Welcome to this DIY project where we'll be transforming old newspapers into a beautiful and functional basket. This eco-friendly craft not only helps reduce waste but also adds a unique, handmade touch to your home decor. Whether you're looking for a new way to store magazines, craft supplies, or other small items, this newspaper basket is both practical and stylish. Let's dive in and get started on creating your very own newspaper basket!
- Old newspapers, paper
- Glue gun
- Glue stick
- Scissors
- Ruler (optional)
- Glue
Step 1: Roll the Newspapers:
- Start by taking old newspapers and rolling them into long, thin pipes. You can use a ruler or any other straight object to help you roll them evenly. Secure the ends with a bit of glue to prevent them from unraveling.
Step 2: Create the Spirals:
- Take one of the rolled newspaper pipes and start rolling it into a spiral. This will be your wall of basket. Make sure the spiral is tight and secure by adding a dab of glue at intervals.
- Continue making spirals in the same way.
Step 3: Form the Base:
Create a large spiral using several newspaper pipes for the base of the basket. Ensure it is sturdy and the pipes are glued securely in place
Step 4: Assemble the Basket Walls:
Heat up your glue gun. Begin attaching the smaller spirals to the edge of the large base spiral, forming the walls of the basket. Arrange them in a circular pattern around the base.
Once you complete the first layer, start adding another layer of spirals on top. Continue until you reach the desired height for your basket.
Step 5: Finish the Top Edge:
- Take one more newspaper pipe and roll it into a circle that matches the top edge of your basket. Glue it in place to create a finished, neat edge.
Step 6: Add the Handle:
For the handle, take another newspaper pipe and attach it to both sides of the basket. Make sure it is secure and can support the weight of the basket's contents.
Step 7: Conclusion:
Enjoy your handmade newspaper basket, perfect for holding magazines, craft supplies, or any other small items. Not only have you created a functional piece, but you've also helped recycle old newspapers into something beautiful and useful.
