Paper Bracelet
Intro: Paper Bracelet
In this instructable you can read how to make a bracelet from an old book, copper wire and some steel wire.
STEP 1: Materials
Materials:
- Copper wire (2 mm)
- Steel wire (0.5 mm)
- Paper from an old book
Tools:
- Steel rod
- Wood glue
- Tape
- Diagonal Cutter
- Needle nose pliers
- Round-nose pliers
- Exacto knife
STEP 2: Cut the Copper Wire
Cut with a diagonal Cutter two pieces of copper wire. Each piece hase to be about 170 mm long.
Tip: Use 170 mm only for someone with a small wrist. For someone with thicker wrists the length of the copper wire must be increased.
Cut also 19 small pieces of copper wire. Eache peache has to about 60 mm long.
Tip: You need more smallpieces of copper wire if you are increasing the length of the bracelet.
STEP 3: Loop
Take the two long pieces of copper wire and make a loop at the end with a round-nose pliers. With some tape of about 15 mm thick, I mark the round-nose plier.
Now take the 19 small pieces of copper wire and make here also a loop at the end. With some tape of about 20 mm thick, I mark the round-nose plier.
Make from one of the two long pieces an omega form withe the round-nose pliers and the needle nose pliers . Measur if the shape of the copper wire fits around your wrist. If not bend the copper wire until it fits loosely around your wrist.
At the end of the omega shape you make a loop, but don't close the loop just yet.
Do the same with the other long piece of copper wire.
STEP 4: Steel Wire
Cut 2 m of steel wire and wind this around one of the omega forms.
First take a piece of steel wire on put this on the omega shape. Now wind the steel wire around the small piece of steel wire and the omega shape.
Make a small knot at the end of the steel wire.
Do the same with the other omega shape.
STEP 5: Paper Rolls
Cut some pages from an old book with an exacto knife. Now cut two blank sides and top of the page away.
To make the paper rolls, I cut a 20 mm wide strip from the paper page. Roll the strip around a steel rod and put some glue (I used wood glue) on the end of the strip. Let the paper roll dry for a few minutes. Make a total of 18 paper rolls.
STEP 6:
Place the paper rolls on the small pieces of copper wire and make a loop at the end of the copper wire.
Do this a total of 18 times for the paper rolls and once for a brass rod. (The brass rod I found among some old brass scrap). If you don't have a brass rod then you may use something else. Otherwise, you can just use a paper roll.
STEP 7: The Bracelet
Place the two omega shapes next to each other and slide a paper roll on the side of the open loops over the omega shapes. Place 9 paper rolls, a brass rod and then 9 paper rolls.
Now you can close the two open loops and your paper bracelet is ready for use.
I hope you enjoy the project and don't forget to vote!
- Thank You!
13 Comments
mrsmerwin 7 years ago
I say one of these on line. I wanted one but never got around to ordering it. Now I am glad I didn't.
kosteej 9 years ago
I love this!! But for the last step, isn't it a little tight trying to fit the smaller paper and copper pieces onto the bands?
NathanBaccon 9 years ago
I love this. I'm making one for my girl friend. I used a midsummers night dream! Thank you sooo much for sharing this!
By the way I found that usually whatever the last three lines were on your paper would be the ones left exposed at the end. So you can cut it and decide what you want it to say.
Diabolik Danger 9 years ago
Actually, the last 6 lines are exposed at the end. Please take a picture of the end result of your bracelet. And I hope your girlfriend will love the bracelet.
Diabolik Danger
BigRed1973 9 years ago
I love this design! Thank you for sharing! Now I have to decide which book to sacrifice........Well done......
Thank you very much BigRed1973. That was my problem too. Which book should I sacrifice for this project. But in the end you shall vindt a book you can use!
emtsevilla 9 years ago
Never underestimate yourself Emtsevilla. How to make jewelry using cardboard and superglue was a splendorous instructable. I bet that you will make a nicer bracelet than mine!
BayRatt 9 years ago
That is pretty neat! Never seen anything like it! Well done!
Thank you BayRatt!
sunshiine 9 years ago
This is so unique! Thanks for sharing your hard work and do have a splendorous spring!
sunshiine
Thank you very much sunshiine and have a nice spring yourself!
